SyafiqSheafi Posted May 31, 2016 Author Report Share Posted May 31, 2016 When i plug my boxer dna 200 my screen on but not charging . When i unplug the cable it cannot turn on . It happen after i change setting on escribe . How to settle my problem ? I try to hard reset but command issue Link to comment Share on other sites More sharing options...
SyafiqSheafi Posted May 31, 2016 Author Report Share Posted May 31, 2016 Only turn on when plug cable into pc but not charging . Help me pls Link to comment Share on other sites More sharing options...
dwcraig1 Posted May 31, 2016 Report Share Posted May 31, 2016 At this time there are only one member beside you and I, I would guess that the fuse has blown.I'm going to delete 3 of your other posts as they say the same thing. Just be patient, more members with technical knowledge will be on soon. Link to comment Share on other sites More sharing options...
mikepetro Posted May 31, 2016 Report Share Posted May 31, 2016 Look at your cell #3. Unplug the battery, or at least the JST connector and manually measure the cells. If cell #3 is truly 0.8v then replace the battery.If cell #3 is more/less normal then RMA the board.While battery is out check the fuse.I hade one very similar, and the battery worked in another mod just fine. Mine looked like this and fuse was good, I RMAd the bard. Link to comment Share on other sites More sharing options...
dwcraig1 Posted May 31, 2016 Report Share Posted May 31, 2016 mikepetro said:Look at your cell #3. Unplug the battery, or at least the JST connector and manually measure the cells. If cell #3 is truly 0.8v then replace the battery.If cell #3 is more/less normal then RMA the board.While battery is out check the fuse.I hade one very similar, and the battery worked in another mod just fine. Mine looked like this and fuse was good, I RMAd the bard.I was thinking it was a 2 cell mod that the OP has. Link to comment Share on other sites More sharing options...
black lace Posted May 31, 2016 Report Share Posted May 31, 2016 am pretty sure that when connected into escribe, 1, select power from the battery drop down list, 2, with batteries removed, will it fire an atty,3, if not you have confirmed a blown fuse..your mod is saying that, that particular battery is dead flat according to the screen, (so you cant expect much to be happening)I would try charging it via an external charger conditioner before condemning it, just incase. Link to comment Share on other sites More sharing options...
mikepetro Posted May 31, 2016 Report Share Posted May 31, 2016 dwcraig1 said:I was thinking it was a 2 cell mod that the OP has.My Bad..... Link to comment Share on other sites More sharing options...
dwcraig1 Posted May 31, 2016 Report Share Posted May 31, 2016 mikepetro said:My Bad.....After looking at the post some more and checking GingerVapes I think it very well is a 3 cell.My bad, I should have ask him when I had the chance. Link to comment Share on other sites More sharing options...
