New mod and questions
Skiddum
Hello guys. I have been tinkering around with escribe and steam engine..And on steam engine it allows you to do a parallel build or single. There's also another area where you can just download the tfr for ss316L. I'm wondering if it's better to do the parallel build cause that's what I'm running or if it's better to do the regular. I can download both and use both. The parallel for the kenthal setting I'm running right now seam to be a bit much. Cause I keep burbing juice and getting dry hits. And I'm running lower than I was on the sigelei 213. So anyways if you guys can help add some info it would be great. After I get home I'm putting in the ss316L but I'm wondering if the wire wizard for for parallel works better http://www.steam-engine.org/wirewiz.asp Or if downloading it from this area and using it works better. Thanks guys in advance. http://www.steam-engine.org/tcr.asp
