Skiddum Posted July 6, 2016 Author Report Posted July 6, 2016 Hello guys. I have been tinkering around with escribe and steam engine..And on steam engine it allows you to do a parallel build or single. There's also another area where you can just download the tfr for ss316L. I'm wondering if it's better to do the parallel build cause that's what I'm running or if it's better to do the regular. I can download both and use both. The parallel for the kenthal setting I'm running right now seam to be a bit much. Cause I keep burbing juice and getting dry hits. And I'm running lower than I was on the sigelei 213. So anyways if you guys can help add some info it would be great. After I get home I'm putting in the ss316L but I'm wondering if the wire wizard for for parallel works better http://www.steam-engine.org/wirewiz.asp Or if downloading it from this area and using it works better. Thanks guys in advance. http://www.steam-engine.org/tcr.asp
Rob_H Posted July 6, 2016 Report Posted July 6, 2016 I am new too and curious for an answer for this. I got my battery set up so far and that is it just vaping away for now, not sure what to do next.
VapingBad Posted July 6, 2016 Report Posted July 6, 2016 If you are just using one type of wire in your coils you only need the profile/csv for that metal, all the other stuff is for mixed metal coils.
