eisenregen Posted July 8, 2016 Author Report Posted July 8, 2016 I'm planning out a desktop mod powered by a wall-power psu in lieu of batteries and I want to have the 510 connection and fire button on a remote handheld piece that connects to the base station via a removable connector. how beefy do I need to go with the connector? Will a little 4 pin aviation connection do the trick or do I need something power rated for the 55 peak amps the chip will put out?
VapingBad Posted July 8, 2016 Report Posted July 8, 2016 The best option is to have the board in the handset, you only have to cope with less than half the current and shorter wires between the board and 510 is better. That way you only need to spec for 23 A so even an XT30 will do the job.
eisenregen Posted July 8, 2016 Author Report Posted July 8, 2016 I know it's not ideal to have the board and remote 510 but aesthetically I'm pretty set on that. I hadn't seen the xt connectors before though, would an xt60 or xt90 stand up to the abuse?
VapingBad Posted July 8, 2016 Report Posted July 8, 2016 On paper an XT60 would (55 A peak), I would use the thickest wire you can to keep the resistance between the board and 510 down.
eisenregen Posted July 8, 2016 Author Report Posted July 8, 2016 thicker than 14 ga stranded copper or?
VapingBad Posted July 8, 2016 Report Posted July 8, 2016 It is hard to say and depends a lot on length, I have not attempted to build something like this so no expert at all, but personally I would look at 12 gauge silicon or ptfe insulated at the very least. I would have a short bit of 14 gauge between the board an plug, but run the majority in 12 or thicker.
eisenregen Posted July 8, 2016 Author Report Posted July 8, 2016 yeah looking at 12 ga silicone between the connector and 510. probably only about 3-5 ft in length. I'm pretty new to this whole thing but I read in another thread that there is a way to calibrate the resistance of the chip to account for mod resistance. Would that help or is it even worth it with 1m+ of copper & a connector in the middle?
VapingBad Posted July 8, 2016 Report Posted July 8, 2016 The first thing is the wire gauge needs to be able to handle 55 A without getting too hot, the second is to minimise resistance for accuracy & efficiency, I would think adjusting the mod res could get good results with 12 gauge. The higher this resistance is the more power the board has to output so keeping it low is desirable. If you had the connector near the board it would be easier to switch to a thicker wire if needed.
eisenregen Posted July 8, 2016 Author Report Posted July 8, 2016 Yeah with the remote just consisting of a holder for the 510 and fire switch it would be cake to swap out thicker wires between the connector and 510. looking like an xt60 for power connection and and audio jack for the fire button with the cables braided together is gonna be the way to go. Thanks for the help!
