What dna200 to get?
francisfilth
Any way someone could post the stock settings on the Hotfire Hero as programmed by Hotfire? I just updated the firmware and forgot to save down the stock settings. Mainly interested in battery and Mod resistance. Also, if you is there any way to exit profile mode once you've already started using a profile? Sorry for the noob question, but just got eScribe to work on my MB.
Sorry for Hi-jacking the thread, but not many people have posted about the Hotfire Hero.... btw that would be my recommendation :thumb: (the thing screams style and build quality is awesome)
You dont need to be connected to escribe .. to Change csv profiles, lock device press all three buttons, up down and fire, scrole to desired profile when promted, Change between your eight presets after setting, from an open mod not locked press both up and down buttons to lock up down buttons, double press either up or down button to enter presets, scroll throguh, select by just using what ever is on screen.
If using a non temp wire like Kanthal it will automatically go into power mode. If you want to use a temp wire in power mode there are a couple of choices, turn temp off on desired profile in EScribe and upload to device or scroll through the temp settings on the device till you get to "OFF" and select with fire button.
  • 2 months later...
