francisfilth Posted April 14, 2016 Author Report Posted April 14, 2016 hey guys i have 3 extra admiral 1300mah 3s lipo batts. what box mod should i get that are lipo batt replaceable on what batts i currently have? thanks
francisfilth Posted April 15, 2016 Author Report Posted April 15, 2016 would i be able to change the battery?
SteelDriver Posted April 15, 2016 Report Posted April 15, 2016 Not easily. Easiest one I've seen is efusion duo it uses 1300 too.
jerome_pylyp Posted April 28, 2016 Report Posted April 28, 2016 Any way someone could post the stock settings on the Hotfire Hero as programmed by Hotfire? I just updated the firmware and forgot to save down the stock settings. Mainly interested in battery and Mod resistance. Also, if you is there any way to exit profile mode once you've already started using a profile? Sorry for the noob question, but just got eScribe to work on my MB. Sorry for Hi-jacking the thread, but not many people have posted about the Hotfire Hero.... btw that would be my recommendation (the thing screams style and build quality is awesome)
dwcraig1 Posted April 28, 2016 Report Posted April 28, 2016 Unless you hit the "restore defaults" button the factory settings should have stayed as is. The battery appears to be the same as the Hotcig DX200(Fullymax 900) so you can probably use the settings for that. It's 10 Wh.
black lace Posted April 28, 2016 Report Posted April 28, 2016 jerome_pylyp said:Any way someone could post the stock settings on the Hotfire Hero as programmed by Hotfire? I just updated the firmware and forgot to save down the stock settings. Mainly interested in battery and Mod resistance. Also, if you is there any way to exit profile mode once you've already started using a profile? Sorry for the noob question, but just got eScribe to work on my MB. Sorry for Hi-jacking the thread, but not many people have posted about the Hotfire Hero.... btw that would be my recommendation  (the thing screams style and build quality is awesome) You dont need to be connected to escribe .. to Change csv profiles, lock device press all three buttons, up down and fire, scrole to desired profile when promted, Change between your eight presets after setting, from an open mod not locked press both up and down buttons to lock up down buttons, double press either up or down button to enter presets, scroll throguh, select by just using what ever is on screen.
jerome_pylyp Posted April 29, 2016 Report Posted April 29, 2016 Yeah, I get all of that. But, once you're using a profile, do you have to continue using profiles? Or can you go back to a factory mode for non-Temp Control use?
dwcraig1 Posted April 29, 2016 Report Posted April 29, 2016 If using a non temp wire like Kanthal it will automatically go into power mode. If you want to use a temp wire in power mode there are a couple of choices, turn temp off on desired profile in EScribe and upload to device or scroll through the temp settings on the device till you get to "OFF" and select with fire button.
black lace Posted April 29, 2016 Report Posted April 29, 2016 jerome_pylyp said:Yeah, I get all of that. But, once you're using a profile, do you have to continue using profiles? Or can you go back to a factory mode for non-Temp Control use? yes is the answere..
jerome_pylyp Posted May 5, 2016 Report Posted May 5, 2016 Does anyone know the case resistance of the Hotfire Hero box? The hotfire stock settings got wiped with the firmware update and system reset.
scott6058 Posted July 24, 2016 Report Posted July 24, 2016 Looks like Hotfire is no longer Sad an awesome mod.
CrookedPenguin Posted July 25, 2016 Report Posted July 25, 2016 akatazmanian said:The VT200 by Hcigar uses 1300mah 3s lipos. It is a very well designed DNA 200The Hcigar VT200 only has a 1000 to 1100mAh battery, it's falsely advertised as 1300mAh.It's fairly easy to replace though, 4 screws and two connectors is all it takes.
