...have also this fine german mod Pipeline PRO 2 that OSD shows all the freezes data of last puff (for some sec.) like TC temp, battery and ohm reached during the puff...I find this bit more interesting than having only the live datas...eventually could be an option in the display section.
PS: or is this already available and I missed it ? Eventually which version of DNA ?
TNX a lot.
Yes within EScribe under the Screen (tab), you can change the DNA display to show:
  • Last Energy (in watt hours)
  • Last Power (in watts)
  • Last Temperature (in C or F)
  • Last Time (seconds of last puff)
I wish they would add "sustained power" too. So they filter out the power it took to heat up the coil and only show the "flat" part of the graph. That way you could more precisely compare and test your build.
