Profile names are the same.
Doyle4
Hello.
Sorry if this has been posted already, new here.
In escribe I gave all my profile's names, but for some reason, all profiles are using profile 1 name, which is Power Mode, so nickel shows - Power Mode Nickel and so on, But i gave it the name Nickel Mode.
Any ideas?
Thanks
If you press connect and download settings in EScribe and they are all the same you have a problem, but I would think it more likely that you are not changing profile on the mod.  Hold down up & down until the msg power or temp locked comes up, then use the up & down buttons to scroll through the profiles and fire to select the one you want.
Thanks @VapingBad,
Escribe see's my profile names that I have set when downloading settings, but when i select them on my device, they are all have Power Mode at top and Nickel for example underneath, this is with all profiles.
Thanks again.
Update: Thanks very much VapingBad, I know now what i was doing wrong, I was selecting different materials in my selected Profile, Your advice worked perfect.
