Hi I'm having issues with my Halcyon I connected it to eScribe and the charging rate is around .17 amps. It's only been charged maybe 4 times, does the charging rate increase over time? Is there something I can do in eScribe that will give me better charging? Thanks
Well I was using the USB port on my keyboard to charge it and I downloaded escribe on my laptop and it showed that it was charging at .5 amps. Luckily it wasn't a problem with my mod, just the power source which is kind of disappointing.
I only charge mine off a 2A USB point on a powerstrip.
In theory, giving the onboard 1A balanced charger a good supply to pull from so it can charge at full rate.
Takes about an hour and a half to come up full from 30%.
USB output is generally equal to or less than the rate on the mod, lengthening charge time.
So I only plug into my laptop when I am adjusting parameters in eScribe.
Also, when I am out and about I keep a Samsung 6000Mah charge pack in my bag.
It pushes 5.1v @1.5A and I can charge it several times before having to recharge the Samsung pack,
and it takes no less time than wall charging it.
