navytech77 Posted October 21, 2016 Author Report Posted October 21, 2016 I just got my vapor shark back from vapor shark they replaced the board as it was a DOA from the vendor. I have it here now and it seems to only be charging to about 90% then the lightening bolt in the battery disappears and the amps drop to .05 I have it plugged into a 2amp charger. Any ideas? Thanks ahead of time.
dwcraig1 Posted October 21, 2016 Report Posted October 21, 2016 A couple of questions. What it does Escribe Device Monitor show for cell voltages? Is your battery set for "maximum puffs" or maximum recharges?
navytech77 Posted October 22, 2016 Author Report Posted October 22, 2016 Thanks for the response I actually unplugged the battery and seems to be working fine now. I'll keep you informed if anything changes. Thanks again.
navytech77 Posted October 22, 2016 Author Report Posted October 22, 2016 dwcraig1 said:A couple of questions. What it does Escribe Device Monitor show for cell voltages? Is your battery set for "maximum puffs" or maximum recharges? Where would this information be at in the device monitor? Just curious. Thanks
Ryan Marc Liversage Posted October 28, 2016 Report Posted October 28, 2016 Please help me out here as i seem to be going through the same issues my dna 200 vs won't charge full it only hits 81% , 5.11V . had a new battery out in and ever since this it is doing it. also if i connect the dan to escribe and restore factory settings it is say it cannot connect to server same as i ask for information on dna same message.
Spector NS5 RD Posted October 28, 2016 Report Posted October 28, 2016 Ryan Marc Liversage said:Please help me out here as i seem to be going through the same issues my dna 200 vs won't charge full it only hits 81% , 5.11V . had a new battery out in and ever since this it is doing it. also if i connect the dan to escribe and restore factory settings it is say it cannot connect to server same as i ask for information on dna same message.i'm pretty sure restoring it to factory settings will reset the board to evolv's settings, not vaporshark's, which you do not want to do. vaporshark actually took the time to set the battery curve, mod resistance and run case analyzer. so you can't connect to escribe?if you can go into escribe......under the "MOD" tab make sure you're settings are at these are my battery settings for my VS DNA 200 they will work just fine for yours. maybe cut the watt hours down to an even 10 watt hours to be on the conservative side.
