mylt1 Posted October 28, 2016 Author Report Share Posted October 28, 2016 i got a VT75 nano the end of last month and it seems to be having issues with the resistance no matter what i do. i use 5 different tanks(2 kanger subtanks and 3 kanger top tanks) and all suffer from the wrong resistance on the 75. they all read correctly and fire correctly on my DNA200. i have messed around in escribe, changing the mods internal resistance and that just seems to make it worse so as it sits the internal resistance is set to 0. i have cleaned the battery cap threads, the 510 threads, the pos pin, and even the 510 disk with no change. so, anyone have any idea on what the issue could be? something internal that needs to be sent back for replacement?OH, forgot to add, the attys all show between .29 and .31 on the DNA200. on the 75 they jump from .27 cold to .37 warm. they can be showing the correct resistance as they should but then not fire correctly. remove the tank, press the fire button, screw the tank back in and then it will show a higher resistance and then will fire correctly even if its as high as .37 on a cold .29 coil. Link to comment Share on other sites More sharing options...
Nick Posted October 28, 2016 Report Share Posted October 28, 2016 I would try removing the screws in the top and bottom of the body, and sliding the battery tube/body away from the frame. You will see the 75 board held in place by three screws, two at the top of the board and one in the bottom left. If you can, make sure those screws are snug, even a 1/4 turn sometimes can be the difference between a good stable resistance reading and an unstable one. Make sure to use the appropriately sized drivers as the screws can be easy to strip if your driver doesn't fit right. Link to comment Share on other sites More sharing options...
mylt1 Posted October 28, 2016 Author Report Share Posted October 28, 2016 i will have to try and hunt down a torqs for that. pretty sure its either a 0 or a 1 and i have nothing even remotely close to that small. Link to comment Share on other sites More sharing options...
Nick Posted October 28, 2016 Report Share Posted October 28, 2016 Don't have a Nano available at the moment but just checked on a VT75 which I would assume uses the same screws, they are a T-6. Link to comment Share on other sites More sharing options...
mylt1 Posted October 28, 2016 Author Report Share Posted October 28, 2016 for the case screws on the top and bottom? they look smaller than a 6. Link to comment Share on other sites More sharing options...
mylt1 Posted October 28, 2016 Author Report Share Posted October 28, 2016 got lucky and found an allen that would fit and not strip the screw heads. took the battery case off, tightened the screws on the board, put it back together and its still doing the same thing. Link to comment Share on other sites More sharing options...
Kostant Posted October 28, 2016 Report Share Posted October 28, 2016 mylt1, I disassembled my VT75 Nano so I can confirm that the 4 case screws (2 on top and 2 on bottom) are Torque 6. Link to comment Share on other sites More sharing options...
mylt1 Posted October 28, 2016 Author Report Share Posted October 28, 2016 already been taken apart and screws tightened, still having the resistance issue. Link to comment Share on other sites More sharing options...
mylt1 Posted October 30, 2016 Author Report Share Posted October 30, 2016 so i have just found something new. it seems the 75 is kicking my SS coils out of temp control and firing them just in wattage mode. the coils work fine on my DNA200 with temp control but the 75 fires for a second in temp then kicks it out. Link to comment Share on other sites More sharing options...
VapingBad Posted October 30, 2016 Report Share Posted October 30, 2016 That is typical of a poor connection, 510 or board ground, ss is more sensitive to it because of the very low TCR. Link to comment Share on other sites More sharing options...
letsavit Posted November 4, 2016 Report Share Posted November 4, 2016 I find my nano 510 can be temperamental.....it prefers attys with protruding positives....try removing the 510 clean with some Ipa and align the 510 nipple on the mod to the center with a screw driver...solved it for me, same problem...good luck. Link to comment Share on other sites More sharing options...
engmia Posted November 5, 2016 Report Share Posted November 5, 2016 [quote]I would try removing the screws in the top and bottom of the body, and sliding the battery tube/body away from the frame. You will see the 75 board held in place by three screws, two at the top of the board and one in the bottom left. If you can, make sure those screws are snug, even a 1/4 turn sometimes can be the difference between a good stable resistance reading and an unstable one. Make sure to use the appropriately sized drivers as the screws can be easy to strip if your driver doesn't fit right.[/quote]Nick is this applicable only when you haven't soldered a negative wire from the 510 to the board and the screws are acting as negatives? Link to comment Share on other sites More sharing options...
