Hello everyone, got my wismec dna200 set for 120watts on the cleito 120 tank at .18ohms with new lg 3000mah batteries.. for some reason it only fires at 80watts. I cant figure out the problem.. please help.. thanks in advance for the replies
You not getting any error messages?
With it set to 120 watts with a .18 ohm Kanthal coil it should fire.
So in EScribe while firing it only reaches 80 watts while firing?  What will it show while firing and not vaping (no airflow)?
I've got to sign off for 5 or 6 hours so maybe someone else can chime in...
Are batteries charged and balanced?
What about battery sag?
Maybe a lot of mass in the coil requiring more time to heat up but some reviewers say no ramp up time.
Are these the coil heads that you are using?
http://www.vaporifics.com/aspire-cleito-120-maxi-watt-coil-0-16ohm-5pk/
They are stainless steel. Are you using them in temp mode or power mode?
