welcome to the forum Do1. you're saying if you take out the batteries and put them back in, the device will not power on unless you first insert a USB cable. you can try and re-install the latest service pack (SP5) and see if that helps. if that does not work, you should first contact the vendor you purchased your Triade from. ask them about a return before contacting Lost Vape's repair center or contacting evolv. Lost Vape has a warranty service center, located in the U.S. Lastly, if all else fails, you can open a help ticket with evolv.
Thx mr now problem is if triade put battery A (3pcs) and change battery B (3pcs) must connected USB first for power ON and than normal work
