Do1 Posted December 21, 2016 Author Report Posted December 21, 2016 Triade dna 200 no display "weak battery" but display battery is empty...help me master...for now im use escribe version 1.2 SP5
VapingBad Posted December 21, 2016 Report Posted December 21, 2016 It is now an option under display to show the message or have the battery tube flash, that was what many users requested here.
Do1 Posted December 21, 2016 Author Report Posted December 21, 2016 Battery in bar is empty but no messages "weak battery"
Do1 Posted December 22, 2016 Author Report Posted December 22, 2016 Update is battery 9% messages is check battery not weak battery
Spector NS5 RD Posted December 22, 2016 Report Posted December 22, 2016 check battery means one or more of the individual cell voltages has reached or dropped below your cell soft cutoff voltage. cells become imbalanced from each other the lower their voltage becomes.you can see this in device monitor. most likely you have a cell that is discharging more than the others. charge your lipo/cells.your watt hour setting is most likely too high. lower your watt hour value. use the watt hour calculator to estimate your cells capacity. this in the "mod" tab of EScribe. or tell me what cells you are using and i can give you an estimated watt hour/capacity for you to use.
Do1 Posted December 22, 2016 Author Report Posted December 22, 2016 My battery use vtc5 master...thx for att...
Spector NS5 RD Posted December 22, 2016 Report Posted December 22, 2016 26-27 watt hours/capacity should get your batter meter very close.
