piggievaper Posted December 23, 2016 Author Report Share Posted December 23, 2016 Hi,I bought an AVATAR RS200W yesterday and i'd like to explain if this is a normal issue on the lipo batt:- It was on 12% charge when i left it on my bag, dully protected.After 2 hours without ussing it, when i fired it the battery charge was at 46%. Then after 5 puffs went down to 36%.Is that normal? how can it go up and down so quick? Another question is:on escribe, ont he mod section, should i clik on maximixe charging or maximize puffs?thanks in advance Link to comment Share on other sites More sharing options...
VapingBad Posted December 23, 2016 Report Share Posted December 23, 2016 I never see them jump up and down that much, check the battery watt hours setting under the Mod tab, you may need to set Options - User interface to Advanced to see them first. Max recharges only charges each cell up to 4.1 V, this should double the life time of your battery and reduce you puff time by less than 10 %Max puffs recharges the cells to the standard 4.2 V.It's personal preference, I use max reccharges. Link to comment Share on other sites More sharing options...
piggievaper Posted December 23, 2016 Author Report Share Posted December 23, 2016 hi thanks for your reply.If i go on advanced mode only appears cell cutoff and charging mode. If i tab on the manufacturer mode it appears more data. Related to WATT HOURS only appears WATT-HOUR CALCULATOR, is that it?if i click it appears a window saying " Do you know the total voltage of your battery pack?Id say the avatar dna 200 runs a 1500mah Lipo. Should i type 1500mah, 3 battery cells? i dont know the nominal pack voltage..thanks Link to comment Share on other sites More sharing options...
piggievaper Posted December 23, 2016 Author Report Share Posted December 23, 2016 it says 12,21 watt hours, does that say something to you?thx Link to comment Share on other sites More sharing options...
piggievaper Posted December 23, 2016 Author Report Share Posted December 23, 2016 sorry, i have typed the correct values and the result is 16,65 wh, which i have changed the cappacity to this value as before it said 8wh.. Link to comment Share on other sites More sharing options...
VapingBad Posted December 23, 2016 Report Share Posted December 23, 2016 Yes for 1500 mAh 16.65 Wh and 3 cell, hopefully that will sort it out, but if the meter still jumps around you probably have a connection issue with the battery or balance connector. Link to comment Share on other sites More sharing options...
piggievaper Posted December 23, 2016 Author Report Share Posted December 23, 2016 VapingBad said: Yes for 1500 mAh 16.65 Wh and 3 cell, hopefully that will sort it out, but if the meter still jumps around you probably have a connection issue with the battery or balance connector. Expand Wonderful thanks! I will make a full charge and use it until battery goes to 0% and will let you know if I have any battery issues. Thx Link to comment Share on other sites More sharing options...
