giz_60 Posted December 31, 2016 Author Report Posted December 31, 2016 Just recently saw an old post about wanting to be able to adjust temp when in TC mode when in the unlocked screen instead of power on the 200 board...and not having to lock the screen to get to the temp adjustment menu. My new LV Therion 166 is has temp adjustments on the unlock screen when in TC mode & power adjustments when in power mode. Is this something only in the 250 board or is there a way to change that in the 200 or 75 board? Would love to set up a couple of my older units to work this way!! Also, I installed a TI config file that I obtained from Daniel on djlsbvapes.com. After that, the unlocked screen was showing power adjustments instead of temperature adjustment...so I know there is a way to change them around but darned if I can find it in Escribe.
retird Posted December 31, 2016 Report Posted December 31, 2016 1. Yes you can set the 200's and 75's to be temp dominate...2. Go into the TI profile from Daniel and set the temp dominant....
