I'm using a Vaporshark DNA 250 but i'd like to increase battery life using a battery bigger than 900mah....can i use a 2200 mah 35C or bigger if dimension are similar?
I would imagine if a bigger mah battery was available VS would have put it in there.... don't think you will find a 2200 mah the same size as a 900 mah and questionable if a 1300 mah will fit ether but it may be close... Google is your friend....
VS designed the box around the battery. this question has been asked multiple times. basically, you're stuck with the 900mah fullymax. there just isn't ANY extra space at all for an increased capacity lipo. if you find something that is bigger, that will be a simple drop-in replacement, let me know.
