yoshiking Posted March 19, 2017 Author Report Share Posted March 19, 2017 I was trying to calibrate my DNA75 device, and after the calibration I have come up across a problem. Here's a run of what I have done.1. Mod resistance calibration. Came out to be 0.004 -> uploaded2. Battery analyzer. Fully charged HG2, soft cell cutoff at 2.5V, battery analysis at 30W -> saved and uploadedNow, after disconnecting from escribe and replacing the battery, 1. It first read the ohms, but started fluctuating. 2. I took off the atty and adjusted 510 (510 pin is adjustable by using screwdriver)3. It is making solid connection, but the ohms read 0.01.4. When I take off the atty, the ohms will still read 0.01. I can even fire the mod. Wattage will go up very slightly then say "Ohms too low" There's no short in the atomizer. Can someone help me diagnose this issue? I can send it back to modder, but the shipping cost is huge (overseas). Link to comment Share on other sites More sharing options...
giz_60 Posted March 20, 2017 Report Share Posted March 20, 2017 Was the device working prior to making the changes?Edit: What is you 75 device? Link to comment Share on other sites More sharing options...
yoshiking Posted March 20, 2017 Author Report Share Posted March 20, 2017 giz_60 said:Was the device working prior to making the changes?Edit: What is you 75 device?It was working fine for a month. Even right before making the changes. It's a DNA75 squonk mod made by Philippine modder called Li-mo. I just wanted to calibrate the mod for better battery efficiency. Original modder setting:Cell soft cut-off : 2vMod resistance : 0 ohmsThe board turns on and fires, but it will keep reading ohm as 0.01 ohm.. even when there's no atty. I do not see any "shorted" or "no atomizer" messages either. Link to comment Share on other sites More sharing options...
giz_60 Posted March 20, 2017 Report Share Posted March 20, 2017 Being a squonker, it's possible that there is some juice between the center pin & ground on the 510 connector on the mod...try cleaning it out really good with some iso alcohol...even could blow it out with some compressed air too... Link to comment Share on other sites More sharing options...
