epsyredemption Posted March 20, 2017 Author Report Posted March 20, 2017 okay so i have had this mod for about a day now was vaping on it just fine and decided to go mess with the setting didn't like how it worked out so i reset it back to factory and now its showing no battery and is not reading my atty i have no idea what could be wrong with it
giz_60 Posted March 20, 2017 Report Posted March 20, 2017 Need more info....What kind of device? Can you post a screen shot of the 'Mod' tab & 'Device Monitor' from Escribe?
epsyredemption Posted March 20, 2017 Author Report Posted March 20, 2017 its the therion dna 166 and do you mean from the dianostics tab?
giz_60 Posted March 20, 2017 Report Posted March 20, 2017 If you used the 'Restore Defaults' under the 'General' tab in Escribe, then your battery settings are probably incorrect...that resets everything to the Evolv defaults, which are configured for a 3 cell setup..Do you see the 'Mod' tab in Escribe? If so, open it & make sure that the battery setting is set for 2 cells. If you don't see it, go to 'Options>User Interface' & select 'Manufacturer'...then you will have the 'Mod' tab available
epsyredemption Posted March 20, 2017 Author Report Posted March 20, 2017 GIZ_60 thank you so freaking much!!!! you are a life saver sorry like i said i just got this mod on saturday you were so helping i really appreciate it so very much!!!!
PaulVapes Posted March 25, 2017 Report Posted March 25, 2017 Newbie here, just seen this post. I am having the same problem, go to the setting that you described, but it doesn't give me the option to change from three to two.Please help, Thanks.Not very good with technology.Update*** Managed to sort it :-)
VapingBad Posted March 25, 2017 Report Posted March 25, 2017 PaulVapes said:Newbie here, just seen this post. I am having the same problem, go to the setting that you described, but it doesn't give me the option to change from three to two.Please help, Thanks.Not very good with technology.You need Options - UI Settings - Manufacture selected.
