DanRyder87 Posted April 9, 2017 Author Report Share Posted April 9, 2017 Ok so i sent an email asking why i was getting an "Ohms to high" message when i got to 5-10% battery. only vaping 55w @ 0.47 ohms dual clapton.He told me i should NEVER ( he capped that) use Samsung 30qs or LGs in any mod. If i wanted better performance or battery life i should buy either VTC5r or His Boxer batteries. Even though they have 400mah less than the LGs and the 30qs they will give alot better battery life due to amperage?Im only pulling 4.89v and 10amps. Can someone tell me what he is on about? Why are 30qs and lgs never to be used in mods? Link to comment Share on other sites More sharing options...
giz_60 Posted April 9, 2017 Report Share Posted April 9, 2017 I use both of those batteries (30q & LG) in my mods everyday without any issues... Link to comment Share on other sites More sharing options...
DanRyder87 Posted April 9, 2017 Author Report Share Posted April 9, 2017 So you also have no clue about what he means? He stumped me. After inputting the correct CSV for my batteries and setting my Watt hours to 19 and my SCC to 2.75 i can get down to 5% before it says "Ohms too low" so im ok with that. I was just wanting to know exactly why it happened from the man himself. Im guessing if i drop my SCC to 2.7 instead of 2.75 il get the last 5% battery? Link to comment Share on other sites More sharing options...
giz_60 Posted April 9, 2017 Report Share Posted April 9, 2017 Even with batteries he is trying to sell ya, or any battery for that matter, you are still going to get the ohms to high message once the battery level gets to the point that your mod can't safely fire the coil... Link to comment Share on other sites More sharing options...
DanRyder87 Posted April 9, 2017 Author Report Share Posted April 9, 2017 No my mod doesnt seem to do that. Il fire at 55w and vape it and it will just go cold as if its stopped firing. Then i look at the screen and it says Ohms too high Link to comment Share on other sites More sharing options...
giz_60 Posted April 9, 2017 Report Share Posted April 9, 2017 Have you ever considered lower ohm build?... Link to comment Share on other sites More sharing options...
DanRyder87 Posted April 9, 2017 Author Report Share Posted April 9, 2017 I dont like hot vapes and i care more for battery life than i do for clouds. At the moment the only wire i have is 26/32 Clapton wire and some clapton SS316L.I have some huge ass framed staple coils that i guess i could use in single coil mode but i dunno what a single coil is like in the aromamizer plus. Link to comment Share on other sites More sharing options...
DanRyder87 Posted April 9, 2017 Author Report Share Posted April 9, 2017 I have pretty much vaped 0.4ohm - 0.5ohm since i started sub ohming haha. Link to comment Share on other sites More sharing options...
giz_60 Posted April 9, 2017 Report Share Posted April 9, 2017 Which is it, you said ohms to high before... .47 is absolutely not to low... Link to comment Share on other sites More sharing options...
DanRyder87 Posted April 9, 2017 Author Report Share Posted April 9, 2017 Yes... Its reading Ohms too High when i get down to like 5% battery. It doesnt fire. lolEDIT: Sorry i didnt see the mistake i made a few posts up. Its deffo Ohms too High Link to comment Share on other sites More sharing options...
giz_60 Posted April 9, 2017 Report Share Posted April 9, 2017 DanRyder87 said:Yes... Its reading Ohms too High when i get down to like 5% battery. It doesnt fire. lolEDIT: Sorry i didnt see the mistake i made a few posts up. Its deffo Ohms too HighIt happens... that's just simply your device not being able to power the coil at that battery level...plain & simple...Edit: Boils down to battery safety... Link to comment Share on other sites More sharing options...
giz_60 Posted April 9, 2017 Report Share Posted April 9, 2017 I have Aromamizer Plus's on 2 of my mods...dual coil builds with clapton wire between .069 & .071 ohms...have never had an issue with 'Ohms To High' before...even on my single battery 75's... Link to comment Share on other sites More sharing options...
DanRyder87 Posted April 9, 2017 Author Report Share Posted April 9, 2017 Oh right. So basically i need to think of 5% battery life as being my "Empty Battery" message and change batteries?Thanks alot. I can stop worrying now. Link to comment Share on other sites More sharing options...
giz_60 Posted April 9, 2017 Report Share Posted April 9, 2017 Worry not...the board is doing what it was designed to do.. Link to comment Share on other sites More sharing options...
DanRyder87 Posted April 9, 2017 Author Report Share Posted April 9, 2017 Thank you my friend. Link to comment Share on other sites More sharing options...
giz_60 Posted April 9, 2017 Report Share Posted April 9, 2017 You bet...on a side note, I have run single coils in the Aromamizer Plus before...running the coil diagonally across the deck, but it don't vape so good for my taste... Link to comment Share on other sites More sharing options...
Spirometry Posted April 10, 2017 Report Share Posted April 10, 2017 giz_60 said:Which is it, you said ohms to high before... .47 is absolutely not to low...0.47 could be too high if he is using SS and a dual cell mod Link to comment Share on other sites More sharing options...
giz_60 Posted April 10, 2017 Report Share Posted April 10, 2017 Spirometry said:0.47 could be too high if he is using SS and a dual cell modAgreed...Boxer 167...he had stated in an earlier post, in another thread....Ohms to High ...so was just verifying which it was... Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted April 10, 2017 Report Share Posted April 10, 2017 ginger's boxer brand 18650's (30a 2600mah) are Sony VTC5A's. i would just buy Sony. cheaper. Link to comment Share on other sites More sharing options...
giz_60 Posted April 10, 2017 Report Share Posted April 10, 2017 ChunkyButt200 said:ginger's boxer brand 18650's (30a 2600mah) are Sony VTC5A's. i would just buy Sony. cheaper.Good info to know...had a feeling they were re-wraps, but wasn't sure what was underneath...thanks CB... Link to comment Share on other sites More sharing options...
