JayD_ITA Posted April 11, 2017 Author Report Posted April 11, 2017 Hello I am a happy owner of dna250.I wanted to ask some things:How do I set the preheat in power mode?In Escribe customizing there are all the "Display variables" but the "last volt" there isn't. How can put it? There is a topic where I can make suggestions for future product versions or firmware?I can set the "board temperature" and "room temperature" in celsius degrees?sorry for my bad english and thanks in advance. 1
retird Posted April 11, 2017 Report Posted April 11, 2017 Work-around for Preheat in Power Mode Topic is here:https://forum.evolvapor.com/topic/65540-topic/I don't recommend this work-around but folks are using it..... You could offer suggestions here for future product/firmware/etc.:https://helpdesk.evolvapor.com/index.php?a=add&category=5
giz_60 Posted April 11, 2017 Report Posted April 11, 2017 JayD_ITA said:How do I set the preheat in power mode?Keep in mind that the DNA boards are not designed for pre-heat in power mode, therefore the workaround 'retird' is referring to is a 'CHEAT'...if at first it doesn't work, you may have to fiddle with the settings to get it to work on your device. Read the thread carefully as there is a lot of info on how to tweak the settings to get it to work...JayD_ITA said:In Escribe customizing there are all the "Display variables" but the "last volt" there isn't. How can put it? This option is not currently available...JayD_ITA said:I can set the "board temperature" and "room temperature" in celsius degrees?That option has been requested a number of times by other users...possibly in a future firmware update...
JayD_ITA Posted April 12, 2017 Author Report Posted April 12, 2017 I would like to thank everyone for the important tips that were given to me!
