jj6404 Posted April 16, 2017 Author Report Share Posted April 16, 2017 Hey guys! I'm so glad to return to the DNA world after my Hcigar VT200 got stolen on a metro bus about 6 months ago. Finally got my hands on a black Therion 166 and loving it. Anyway, I grabbed a pair of the new VTC6s off orbtronic for this mod and am having some trouble with the battery settings. I got it set Lithium polymer, and 3000 mAh, 2 cell, 7.4 pack voltage in the watt-hour calc. But everytime I pop them in freshly charged it shows 91% on my Therion and seems to go down quickly from there. I've got do be doing something wrong...Right? From what I've read you're supposed to put nominal voltage for the pack voltage. But the listed nominal voltage does vary for these VTC6s from 3.6-3.7 depending on what source you read... Any help would be greatly appreciated! Link to comment Share on other sites More sharing options...
dwcraig1 Posted April 16, 2017 Report Share Posted April 16, 2017 Reduce your watt hours by 10% or so and it should put it at 100%It is a common occurrence. 1 Link to comment Share on other sites More sharing options...
giz_60 Posted April 16, 2017 Report Share Posted April 16, 2017 Here is the .csv for those cells... Sony_VTC6 (2)_18650_3000 mah_19.96 Wh.csv Wh's is in the file name...this .csv was generated with the battery analyzer in Escribe on a Therion 166 Link to comment Share on other sites More sharing options...
jj6404 Posted April 16, 2017 Author Report Share Posted April 16, 2017 Thanks guys. Looks accurate now. Out of curiosity, the watt-hours should be more than 19.96, right? Why do we even have to "trick" the board to display accurate battery life? Link to comment Share on other sites More sharing options...
dwcraig1 Posted April 16, 2017 Report Share Posted April 16, 2017 Well one reason it the battery has it's mah rated between 2.5 volts and 4.2 volts and the board is using it between 2.8 volts and 4.2 volts (just example) 1 Link to comment Share on other sites More sharing options...
giz_60 Posted April 16, 2017 Report Share Posted April 16, 2017 And, all Wh calculators are going to give you the 22.2 Wh value on a pair of 3000 mah 18650 batteries, even though not all batteries are alike...it's a mathematical equation...but by analyzing the batteries over a period of time, you will get a more accurate Wh value for that set..for example, on the LG Hg 2's, the analyzer came up with 18.75 Wh's & on the Sammy 30Q's, 19.25 Wh's...all 3000 mah 18650's (2 cells)...so, you're not 'tricking' the board, just giving it a more realistic Wh value Link to comment Share on other sites More sharing options...
