esamalamad Posted February 28, 2017 Author Report Posted February 28, 2017 Ok so i accidentally restored to default my new ONI 167 DNA 250 using 2 18650's LG HG2I received the original factory file from Asmodus, however they have currently set it up for 3 batteries which makes no sense as the ONI is dual battery, What i need your help with is the following:1) The numbers to set the battery for 2 cells LG HG2: I know its 3000mAh, and nominal voltage is 3.6 ( i entered 7.2 for 2 x 18650's) , this gives me 21.6 watt hours- Is this correct? the initial setting was set at 9 so I'm worried mine is too high?2) the soft cutt off : I'm not sure what to set the cut off point at for the LG HG2Thank you in advance for your input
dwcraig1 Posted February 28, 2017 Report Posted February 28, 2017 If it were mine I'd use 19.5 wh and soft cell cutoff of 2.85 v
esamalamad Posted February 28, 2017 Author Report Posted February 28, 2017 Thanks for the reply, just wondering is there a calculation or is This based on preference? How low can I go with LGHG2 withiut sacrificing battery life by over discharging? Also how did u get 19 if I may ask, thank you
dwcraig1 Posted February 28, 2017 Report Posted February 28, 2017 Being the board has a hardware cutoff of 2.85 because it's designed for a LiPo. LiPo has mah rated between 3 volts ant 4.2 volts. A IMR round cell has it's mah rated between 2.5 volts and 4.2 volts. So with a 200/250 board the capacity between 2.5 and 2.85 volts isn't able to be used. What I do is subtract about 12% for what the calculator comes up with when using round cells. It's much easier on the cells to not use them to their lowest point.
giz_60 Posted February 28, 2017 Report Posted February 28, 2017 Here is a .csv file for 2 LG HG2's...it was generated by using the battery analyzer in Escribe....dwcraig is correct in the Wh figure, as I have found that the calculator almost always give a higher, perfect situation, Wh value then the battery analyzer, real situation, does. LG_HG2 (2)_18650_3000 mah_18.75 Wh.csv Edit: Could you post that factory .ecig file for the ONI167...am curious as to the other settings as well..Thanks!!
esamalamad Posted February 28, 2017 Author Report Posted February 28, 2017 Thank you both so much, sorry I'm new to escribe, so I upload this in the batteries section and then do I keep the watt hours and other field blank? Or will it fill them in for me?
giz_60 Posted February 28, 2017 Report Posted February 28, 2017 You will have to set the Wh's yourself, only the curve profile will load...Edit: And don't forget to upload to device once done...
esamalamad Posted February 28, 2017 Author Report Posted February 28, 2017 So I should set it at 18.75? What about the cut off set point? Thanks again
giz_60 Posted February 28, 2017 Report Posted February 28, 2017 esamalamad said: So I should set it at 18.75? What about the cut off set point? Thanks again Expand That is good, and the 2.85 dw mentioned will work as well...
FilthyMick Posted May 8, 2017 Report Posted May 8, 2017 esamalamad said: I received the original factory file from Asmodus Expand Can you please share the file with us? I could really use this, as I did the same thing, and need the original settings as well. Thank you!
