bluntmoment Posted May 11, 2017 Author Report Share Posted May 11, 2017 need some help here, I am looking to use fire buttons with leds on my DNA 250 builds. Cannot seem to find a clear answer on where to solder on the board for the led portion. Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted May 11, 2017 Report Share Posted May 11, 2017 here in this diagram you can see where at the top right of the fire button you can tap into the LED pads. just make sure you have your polarity correct when hooking up LED. Link to comment Share on other sites More sharing options...
bluntmoment Posted May 11, 2017 Author Report Share Posted May 11, 2017 thank you. it looks easy enough I suppose. Any suggestions on where to find the resistors? Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted May 11, 2017 Report Share Posted May 11, 2017 what color is your LED? I'm gonna guess blue???? you need a 100 ohm resistor. red, yellow or green - 75 ohm. got a radio shack near by (?) or just go on ebay and type in "100 ohm 1/10 watt resistor" depending on your soldering skills, maybe get through hole resistors rather than SMD ones. check to see if the switch you're buying already has a resistor inside, you may not need to buy one separately. Link to comment Share on other sites More sharing options...
d1lyh4n4 Posted June 7, 2017 Report Share Posted June 7, 2017 Easy until you try it and those tabs snap of if you breath in them. Worst designed part of this board. I would like to know if anyone has the schematic for a battery direct connection for the led since i now have no pads to solder to. Also using white LED and a 4 pin button. Link to comment Share on other sites More sharing options...
