Joshua12345
Everything posted by Joshua12345
update: i put the default 100c theme on and it made no difference. it is still doing the wattage drop issue. i honestly think there is something wrong with a connection inside the mod itself
Okay so I’m this picture, I have a fully charged Samsung 40 t. The device is set on 80 watts. During a regular hit, it is hitting at 4.17 volts. Once the screen went black, it appears to be hitting at 46 watts, it also appears the volts went down. But after this, if I keep hitting it.. it still says upper 4 volts
The weak battery thing isn’t really an issue. I just assume that’s because I’m running it too high. And when it hits at half watts with the screen black, the voltage stays the same. The only thing that changes is the watts
I will do this once I get home
I’m only getting a low battery message trying to fire at ninety. But the main problem is everytime I hit it and it’s in the black screen, i have it set at 70 and it hits at forty something. But as soon as I fire it again it’s normal
Yeah, I’m at work all day. I restored it again, and don’t hit over seventy watts, and the problem doesn’t occur. It’s only if I’m running high wTtage, as well as weak battery on a full charged batt
update: problem started again
I guess I might have accidentally done something to it either on escribe when I first got it or on the mod itself. Lol maybe this was all self inflicted. Idk but I appreciate you guys
Still the boxer theme. It’s almost like something had been tweaked on escribe before I ever got the device possibly. Because once restored.. so far it’s working fine.
Yeah, I never had a chance to take it off, I hit restore defaults before I ever downloaded the theme you sent, changed the screen to have a hit counter on it, uploaded these settings, and it hasn’t messed up since. If it does mess up again, I will send a post. But otherwise, thank you guys so much for caring enough to help
Did you try this @dwcraig1? Restore defaults?
ok, so before i try the default theme, i hit restore all the defaults, and now it appears to be working right. i cant get it to fire the wrong low wattage, even when the screen goes blank. im going to keep a watch on it, and finish building the other atomizer i was using that was messing up on it, and see what happens. i really appreciate everyones help and would appreciate if you would continue to get notifications from this thread for the next day or so just to make sure it doesnt start messing up again. i will let you know either way
@Wayneo I’ll try whatever you think will fix it. This is my first boxer and I was so excited to have it and I’m so like weirded out that it might possibly be messing up
Yes, I was using watts profile two, that file I don’t think got a clear recording, because I didn’t know what I was doing. The problem I’m having is clearly going on in the pictures
Sounds good @wayneo
It was not checked under any profile
How do I unlock?
This problem literally only occurs if hitting mod after screen has gone black. It will continue to hit at seventy or right under over and over until the screen turned off, then hitting the button to fire and waking it up at the same time, it will fire at 40 something
Did I not post it right? I thought I took the recording, am I supposed to take a screenshot or something?
i deleted the post with the wrong recording.. this one above should show it firing like i feel its not supposed too
i posted the wrong recording. this is it. set at 70, hitting at 69, then 44 josh 2 record.csv
here is the recording of it firing normal, and having the problem. my device is set on 70 watts the whole time, it fired at 69 and then once the screen went black it fired on 42 or 43. can you see this? josh recording.csv
here is the escribe file, pls tell me if this is what you requested/ what you find. i added the service pack also josh escribe.ecig
