Terra
Everything posted by Terra
  1. Just downloaded again (after shift-reload) using link above: https://forum.evolvapor.com/applications/core/interface/file/attachment.php?id=238407 sha1sum: 96cbe7f887410592874e93ea1dec3da28a1ec177 *Evolv Default Enhanced 250C.ecigtheme Still showing 3.3
  2. Perfect, works great, thank you very much for being so responsive! Now I don't have to manually update the theme to include this anymore each time you make a new release. One minor issue, the About::Theme Rev still shows 3.3
  3. I'd like to make a suggestion for the main screen. There is an available slot at the bottom (occupied by a red DNA), and I tweaked your Theme to put a "clock" there. -------------- [....] 24 W MENU 08:19am -------------- *sorry about the ASCII art, I couldn't upload a JPG image file. (ThemeClockTweak.jpg - 9kb - Upload Failed) Main Screen Clock Tweak My mod is usually on this screen because I use Kanthal profile in wattage mode. What do you think about making this a permanent feature of your theme?
  4. Never mind, I figured it out. Had to enable the (advanced) Manufacturer settings in EScribe and increase the "Manufacturer Max Puff Time" as well (it was still set to 10s). The Theme is now properly handling the full "Max Puff Time" increment range of: 0-20
  5. Mod: Lost Vape Paranormal DNA250C I'm using 3.2 and I'm having an issue with "max puff time". I have changed it via: Safety->"Max Puff Time" = 20s I like to use lower wattage, preheat then take longer RTL hits so the average ends up being ~13s. Yes I know I can bounce the fire button, but that messes up my Puff Info statistics. In the theme, it shows up as: 20s (in orange) and if I try to adjust it, it will drop to the default "10s" and cannot increase over "10s" However, the worst part is that even when set to "20s" the mod will not fire beyond "10s". I do not know if this is an issue with my mod or with a theme field control. Other than this issue, I love this well thought out and advanced Theme.
