conradisrugged
Everything posted by conradisrugged
  1. Hi it’s update time, Last night I took out my batteries and left my device unpowered for about 5 minutes before I put in new batteries and it simply would not turn on. I then plugged the USB into my computer and then into the device and it turned on. I repeated this process again and it happened again. I carried on using the device and charged the batteries full within the device and took them out and I think I found what the problem was. Each time my device has been without power and I turn it on and it refuses, my Mad Dog RDA has been on the device. I left the device off over night with the batteries out and no RDA or Tank on it when I turned it on this morning with a fresh set of batteries inside. It turned on instantly. Im not sure why it does this with the Mad Dog RDA because it doesn’t happen with the Vandy Vape Pulse 24 or Wotofo Bravo. I will do more testing and update.
  2. Hi I might be able to help, my mod reset the time last night but it retained my Replay settings. I'm under the impression they are independent from each other, as someone else said, lets wait and hear from an Evolv expert.
  3. Update: So I repeated the same thing I did the night before it didn't turn on. I took out the batteries and put a fresh pair in, it turned on after pressing the fire button and worked for my good night vape. I left it over night and it went into standby/sleep after an hour. This morning when I woke up I turned it on with no problem, very responsive compared to 5 days ago, the only thing that was a bit troublesome was that the time was now ahead by 2 hours and the date was set to 1/1/00. I'm not sure what the problem could be or if there is even a problem. Kind regards, Conrad
  4. Hey again, I did a hard reboot, reapplied the service pack, and I’m not sure of the exact term in escribe but reset the device to manufacturer settings where it looks for the mod online and reapplied the default settings. I then did another hard reboot then a soft reboot and have not set the idle/sleep time and left it at the default 60m. So far I am unable to replicate the initial issue, I don’t even have the delay from wake as the display lights up instantly. I will update if it happens again or does not to conclude if it might have been the theme some how causing the problem. Kind regards, Conrad
  5. Hi Guys and gals, I'm new to a DNA board so I was hoping you could help me out. My Lost Vape Paranormal 250C has been working great in all respects since i've had it for the past 9 days, in the last 4 or so days after I put a theme on(Timmy TimBit's Material Dark or something) my device would take unusually long to wake up from sleep with multiple clicks to wake up sometimes, and maybe 5 seconds later springing to life. Last night before bed I had put in some fresh batteries and then this morning when I tried to turn it on it just refused, it would not, I then plugged it in to a USB port and connected it to the device with the other end of the USB cable and it turned on and it has been working fine ever since. What could the issue be? I read it may be the battery sled problem, however I made no adjustments to the door before I plugged it in so I doubt its that. Could it be the chip? I don't want to think its the chip because everything works well apart from the waking from sleep after about 3-4 hours and the sleep time is set to something like 5 minutes. Kind regards, Conrad
  6. Version 1.0.0
    448 downloads
    Original Theme by Tad, modified to be a bit more subtle and added and removed a few things. Customized for the Lost Vape Paranormal 250C. Extract from Original Theme "Theme in the style of Material Design for Android Wear. Coil material, temperature, watts, and resistance settings are all accessible from the main screen. Additional settings are consolidated in one menu tree, similar to Android devices. Based on the default Paranormal 75C theme by DJLsb Vapes."
