Everything posted by Mr.Bottomfeeder
Hello my friends, now, my theme "Mr. Theo Bottomfeeder" is availiable in the V 1.8.1 with Replay-Mode . Just some (hopefully) last minor bugfixes in this Update. How the Theme works, you can see in the overview-picture below. The theme is availiable in german and english version. Unfortunately I don't own a DNA 250C-device. So no Powerbank-features are included in this theme. Wish to have fun with this new version Greetings Mr. Theo Bottomfeeder Black V1.8.1 German for DNA 75C.ecigtheme Mr. Theo Bottomfeeder Black V1.8.1 English for DNA 75C.ecigtheme
Hello Retird, No problem - for me, my Theme works perfect with Replay on all my devices. Now, I can use all the wires, I have as spare with a function like TC (I know, it isn't really TC, but it's a protection against Dryburn at all) As I read meanwhile, Kanthal is just supported by the DNA 250, but not by the small DNA 75C. The only one Battery seems to be the reason - too less power for. But with choosen TC-Mode, in my Origen little RDA my beloved Zirconia-wire works with Replay and in pure Wattage-Mode Replay also works fine (have with Nickle 200-Wire). First time in my live, I have a Dual-Coil-RDA Wotofo Serpent BF in using. With two Ni200 each 5Wicks x 2,5mm inside - this in Wattage-Mode + Boost. And with Replay activated. Have to say, I could get used to that. Just the wide bore Origin DripTip from this RDA isn't really according to my taste.
Hello Retird, have tested the Replay with my theme. With Zirconia- and Nickel-Wires, it works fine on my Device. Just with using Kanthal, I could not switch Replay into Record- and Play-Mode. Only, If a coil has no really fixed Screws and the resistant is changing in a wide range or the coil hits the case, Replay also could not be recording and Playback on my device. If the coil is correct inserted in the RDA, everything works. Don't know, why you have problems unfortunately.
Hello Retird, Thanks for your help again. Have downloaded the english theme from my links here - it's same as I have here on my harddisk. Well, I found a complete english version on my Backup-Drive. So it isn't hard to fix the missing translations. But the problem with Replay I can't reproduce. If I swap between my english and german theme with EScribe, it doessn't matter, what the Repeat-State in prevoius Theme was on the device. Also, if I change the Themes with the Team-Designer. If using EScribe for uploading, I have the "Halt"-Symbol on mainscreen. If using Theme-Designer, I get the previous Repeat-State like before exchange the Themes. Both ways, I am able to switch the Repeat with it's Repeat-Symbol on the mainpage as well as with the buttons on the Repeat-page. After uploading a new theme, and unlocking the device, first I get a "New-Coil"-Info when first fireing. After puffing, it changes to the red filled circle, that diaplays recording is available. When clicking this symbol, it changes into the red filled triangle what shows Repeat is avtive. Same time the big yellow "Repeat" is displayed on the screen. Coul'd it be, you have activated "Puff saved, playing" in your EScribe-Profile-Settings? As I wrote in the Credits of my themes, this could getting problems when changing between themes. Seems better, to leave this checkbox unactivated. Unfortunately, I can't find other reasons for your problem in moment.
Hello my friends, now, my theme "Mr. Theo Bottomfeeder" is availiable in the V 1.8.0 . Some minor improvements, but as major highlight, the Replay-Mode is integrated now. How it works, you can see in the overview-picture The theme is availiable in german an english version. Would be very kind, if User Retird could test the english version once again. He helped me to fix the problem in last versions. Wish to have fun with this new version Greetings Mr. Theo Bottomfeeder Black V1.8.0 English for DNA 75C.ecigtheme Mr. Theo Bottomfeeder Black V1.8.0 German for DNA 75C.ecigtheme
Hi, Had a little time today. So I improved and expanded settings and info menues. Also did little changes in other menues. See pic below for new menu-structure. Hope, you have fun with. Regards Mr. Theo Bottomfeeder Black V1.7.0 German for DNA 75C.ecigtheme Mr. Theo Bottomfeeder Black V1.7.0 English for DNA 75C.ecigtheme
Hello friends, Seems a little quiet here, no responses at all... Here the final verison V1.6 what brings a additional Menu with just important values but this in big chars This Theme I have translated in english language as well, for users that don't speak german. Have fun with Mr. Theo Bottomfeeder Black V1.6 German for DNA 75C.ecigtheme Mr. Theo Bottomfeeder Black V1.6 English for DNA 75C.ecigtheme
Well, I did some more changes. Here V1.5 what shows more informations on main screen and give more direct access to lower menues by the main screen. Now it seems perfect to me. Have fun with it Greetings Mr. Theo Bottomfeeder Black V1.5 German for DNA 75C.ecigtheme Mr. Theo Bottomfeeder Black V1.5 German for DNA 75C.ecig
Hello, if wrong in this category - sorry, could not find a better matching category for this question. My question: I have uploaded my theme in category "Downloads" - "DNA 75 Color". But now, there is an exclamation mark in front of the new posting and it is invisible to other users ecept me. What could be reason for hide my theme for others? Still wonder why... Kind regards
Here my first Theme for the DNA 75C (using Therion BF 75) in german language. It is a very comfortable theme in black - easy for viewing display in dark and bright background. Hoping everything works well - if you find some problems or missfunctions or having questions, please feel free to drop me a note here. Mainscreen: Left side: Temperature-Icon Shows activated if actual profile is temp-protected Shows deactivated, if no activated Temp Protect or coil with no Temp Sensing Material or coil with Temp Sensing Material but no Temp Sensing detected (wrong coil-wire for choosen Profile) Right side: Coil-Icon Dark coil with both pins down, if Boost deactivated and no Tempsense-Material and no Temp Sence Detect (usual Watt-mode) Dark coil with right pin up, if Boost activated and no Tempsense-Material and no Temp Sense detect (usual Watt-mode with Boost) White coil with both pins down, if Temp Protect deactivated and Tempmaterial but no Tenpsense detected (mostly Temp Protect with Temp Sensing wire - but wrong TC-wire used) White coil right pin up, if Temp Protect activated and Tempmaterial but no Tempsense detected (mostly no Temp Protect with Temp Sensing wire - but wrong TC-wire used) Red coil both pins down, if Tempmaterial and Tempsense detect but no TempProtect activated (TC-wire with not activated Temp Protect) Red coil right pin up, if Tempmaterial and Tempsense detected and Temp Protect activated (full working Temp Sensing Mode, TC-wire with activated Temp Protect) Voltage-state displayed in different colors. USB-Loading and Lo-Voltage-Alert when using is displayed in relevant menus All other elements should be self declared. :-) General movement across the menus see graphic below. Wish to have fun with it Kind regards Mr. Theo Bottomfeeder Black V1.0 for DNA 75C.ecig Mr. Theo Bottomfeeder Black V1.1 for DNA 75C.ecigtheme
