Pjr's Achievements
Evolv sent me a package containing the black piece for my broken batt door. Thanks Evolv!
- 16 replies
- 1
- paranormal dna door weak
- paranormal dna door broke
- (and 2 more)
I am still waiting for my battery door. It's been over a week since Evolv sent it...
- 16 replies
- (and 2 more)
@TNT0305 I'll ask my friend to help me out when I get my package from Evolv.
- 16 replies
- (and 2 more)
@dwcraig1 Got an email from Evolv, they sent me a batt door for my Paranormal DNA 75c. Just waiting for the package, it was shipped last Friday. Most probably it will be here next week. Thanks for sending me that link. Tc!
- 16 replies
- 1
- (and 2 more)
@dwcraig1 Thanks Man! Just sent them a ticket. Waiting for their reply. 😊
- 16 replies
- (and 2 more)
@TNT0305 How did you contact them? So happy for you. Would you be kind enough to share the email and phone number to me? So I could talk to them too, about my batt door... Thanks😊
- 16 replies
- (and 2 more)
@TNT0305 Also, if you happen to know somebody, who could create a 3d file of your para batt door, you could have it 3d printed. Check 3d printing battery door on youtube.
- 16 replies
- (and 2 more)
Hi! @TNT0305 I tried messaging Lost Vape, and I'm still waiting for a reply. No confirmation or anything. What I did was, removed the hinges totally and just open and close the batt door manually. I hope you get your mod's batt door replacement soon.😊
- 16 replies
- (and 2 more)
Hi! My Lost Vape Paranormal 75c's battery door broke off. Had it's very thin hinges loose for the past weeks then it went off totally today. Has anybody experienced this, and found a fix? Thanks!
- 16 replies
- (and 2 more)
Al last! I have found the best setup for my Paranormal DNA 75c. I have experimented on almost 25 atomizers from rbas, rdas, rdtas and rtas since I started vaping. I would like to share this with you guys. This has given me the most satisfying vapor and never ending flavor as I chain vape everyday. 😊 Ohms .77 upto 1.0 Interval is 5 to 10 mins every 3 to 4 hits daily I use cotton bacon v2 Just right snug not too tight not too thick Wicks should be longer so there will be no dry hits I use a kclapton 26g 32g coil and build a 3.5mm 6 loops on my single coil zeus rta. The build should be as high as possible to get an awesome flavor. I run my paranormal dna 75c at 30 to 40w My batteries are Vtc4 the best battery and with my current build this could last for the entire day and mod does not warm up or get hot at you vape. Cylaid Strong for the first 6 hours then once it hits 25% it is as good as zero power Lg choco Performance in variable mods is good and safe, however the aromizer gets warm easily and so as the mod. I highly recommend vtc4 as I use it for most of my variable setups It is as good on a series mod too judt a shorter battery life as compared to my dna 75c which is a dual parallel mod
- best setup dna 75c
- best atomizer for dna 75c
- (and 4 more)
There may be a delay on the values showing on the screen. It was working okay when you press it longer, volts show up. After rewicking though, the volts change as I fire. Which never happened before.
Hi guys! I'm new to vaping and I just need some inputs and suggestions from pros like u guys.😊 Mod: paranormal DNA 75 c Atty: wasp nano rdta (single coil) Current build: dc Clapton wire 26 gauge, 7loops What's the best wattage to vape on? If I vape at 40w, volts go up to 5.45 Ohms at .6 when the coil heats up goes up a bit up to .7 Haven't found my vape's sweet spot yet. Scared of ramping up the wattage, because the voltage goes high too. 😊 I also get spitbacks at 35-40w sometimes. Build was done yesterday at the local shop.
- 2 replies
- ohms jumpihg
- ohms changing
- (and 4 more)
Hi, i'm new to DNA. I have dna 75c paranormal and hcigar vt75 nano dna. Got 2 attys built in dc clapton wires 26g 7 loops on smm rta and 7 loops on wasp nano rdta both are single coiled atty. I noticed my mod's resistance from.66 jumps to .71 everytime I vape it. I tried using both attys on the hcigar, there it's worse. The jump goes from .60 down to .4 and other numbers. With the paranormal, from .66 to .71 every hit. I only vape at 40watts on both mods. Your answers will be much appreciated. Cheers! Poj
Hi, i'm new to DNA. I have dna 75c paranormal and hcigar vt75 nano dna. Got 2 attys built in dc clapton wires 26g 7 loops on smm rta and 7 loops wasp nano rdta both have single coiled atty. I noticed my mod's resistance from.66 jumps to .71 everytime I vape it. I tried using both attys on the hcigar, there it's worse. The jump goes from .60 down to .4 and other numbers. With the paranormal, from .66 to .71 every hit. Your answers will be much appreciated. Cheers! Poj
- 2 replies
- ohms jumpihg
- ohms changing
- (and 4 more)
Hi! Nobbi, I have the same mod and the resistance jumps from .66-.71 when firing. I just noticed it. Will take my mod to a local vape shop to get it fixed.
