JaySoCal
JaySoCal's Achievements
				stay away from fat daddy vapes v5 510
JaySoCal replied to JaySoCal's topic in Connectors, Components, and Accessories
Stay away from fat daddy vapes 510. I know very bold and forward but let me explain. Been through 3 dna boards. The first one never came on so doubt it is related to this issue. The next 2 maybe. The ceramic insulator has no retention groove and will eventually move in the 510. The 2nd board worked great for a few weeks then restiance would fluctuate. Thought it was the clone rda so bought a authentic twisted mess rda. It was better but still some. Then it fried sent it in for warranty. 3rd board same thing but this time I got warranty service. Now on the 4th board was vaping on it a few weeks ago started do the same thing but was taking a vape and the check atomizer was displayed. So grabbed the atty and it was loose huh? Vaped it a little while longer was acting weird then check atomizer agian. But this time it is tight. Huh? Tale the back off the + wire is unsoldered form the 510. Huh?. I re-solder it to the 510 but still getting check atomizer weird right. So decide to push on the 510 with a screw driver it moved. Un soldered it and took the 510 out of the mod and the ceramic was cracked and allowed the positive pin to be close to the outside. Not a full short but close to it may of been intermittently allowing a short. Put a varitube v2 510 mod runs totally diffrent ohms don't jump feels way smoother. -
	Don't give up I love the chip. I wish all mine where the same problem so I could find the root cause but one day it will be problem free.
	One quick way I have found if my atty falls out of temp control is vape it in non tc 2 to 3 puffs. Remove the atty so resistance shows 0 on the mod. Suck through it a few times to cool coil. Then reattach atty select old coil then it jumps back in temp control. Just make shure you don't select new coil resistance will be wrong if it goes into temp control and can make it harder to get it to go into temp control
	I have had 3 boards fail but all diffrent first one dead when I got it second fuse 3rd warranty service.
	Know how u all feel lol. Bought my board in august dead on arrival. So after trying to trouble shoot it via email got a rma got it back first part of September. Worked great till October fuse blew. Board 3 got back working first part of November till the other day got the dreaded warranty service message.checked voltage of the battery and tried 2 other battery's. Love the dna 200 just hate the headache hopefully the next one is the one for my mod.
	One thing I have found for battery not fully charging is after it reaches 100% screen stays on but charge never resumes as voltage drops.
	Aww the dreaded dual coil temp control lol. Been doing alot of hybrid complex builds in dual using 24g grade 1 ti. Been loving it but using kanthal with temp control causes more issues with hot spots and by nature pulling heat out of the temp wires. Stability of atomizer is first and for most. They are all contact coils but due to the no dry burn getting hot spots out is hard normally 10 to 15w pulse but no glow. Then alot of times I'll vape them in non tc mode at 30 to 40 watts for a few days. Then they seem to run fine after I give them a little time to work themselves out. Leg length is probably the second most important part.
				What size NI/TI wire to get! (And post your builds!)
JaySoCal replied to blank's topic in DNA 200 and 250
I have 26g and 28g ni200 played with it for a while had a funny metalic taste when coil would run dry/temp protection. And have been loving 24g ti grade 1 spaced or complex builds it runs rock soild. Just have found with helix or staple builds run at a low wattage first due to the fact you can't dry burn and work hot spots or build a oxidation layer on the kanthal. -
	Don't have a picture but using 24g ti helix single coil on a velocity clone temp control works awesome. It's (x2) 24g ti grade 1 (4x) .5 x.1 kanthal ribbon wrapped with 40g kanthal. Due to the amount of non tc metal don't really like to run over 350 degrees hard for temp control to catch it at the set temp due to it heating up the kanthal. When I first built it the chip had issues with it and I finally figured out it was due to hot spots in the coil and not being able to dry fire it. Just took a little time for that to work itself out just vapes it at 30 to 40 watts and made shure it stayed wet without t/c. Been working flawless for 2 weeks now .12 ohms stable and no ohms lock. Tons of flavor and vapor. I'll see if I can get a pic with my phone when I get home.
	As the cells get closer to full charge it starts to lower the amps if it's doing it when the battery not close to fully charged either a connection that's not fully conductive or the usb plug is lowering the amperage.
	Fda is being pushed into e cig regulation with a ridiculous grandfather date of 2007 so allmost all mods,tanks,attys we have grown to love or future new progress like the dna 200 and beyond may never agian see the light of day on b&m shelves or Internet stores. Please contact your representative in the Senate or congress and call the white house to help stop .this.copy and paste the link and save our vape . http://blog.casaa.org/2015/10/national-call-to-action-tell-white.html?m=1 If this does pass no new hardware we will be stuck with big tobaccos cigalikes hmmm wonder who is pushing this forward
				Resistance still climbs while it's supposed to be locked?
JaySoCal replied to p8ntballa9362's topic in DNA 200 and 250
I think what is being asked here is if the resistance is locked the display next to the lock symbol is changing so what the op wants to know is that showing the locked ohms or the live ohms -
				What is the resolution of the resistance measurement?
JaySoCal replied to Bobby's topic in DNA 200 and 250
In another thread about temp control John or Brandon said it is .000000 or .00000000 did a quick search but couldn't find it might of been before the Korean spam invasion. -
	Went through and checked all the solder joints and connections all appear to be soild. I use to assemble circuit boards for clean room controllers. They use them in clean room that they make micro chips. Was wondering though about board flex with only 3 mounting points maybe flexing someway and internally have a issues
