            gorman
                Posts18
                Days Won2
Everything posted by gorman
	  Early Firmware and EScribe Suite Discussion Threadgorman replied to David Campbell's topic in EScribe, Software and Firmware It's all good, don't worry.
	  Early Firmware and EScribe Suite Discussion Threadgorman replied to David Campbell's topic in EScribe, Software and Firmware For regular DNA75? Not 75C.
	  Early Firmware and EScribe Suite Discussion Threadgorman replied to David Campbell's topic in EScribe, Software and Firmware Yes, I was talking about DNA75, not 75C. Boost was added to that "old" generation on other, less widely used, chips and DNA75 was meant to get it. Then everything fell quiet.
	  Early Firmware and EScribe Suite Discussion Threadgorman replied to David Campbell's topic in EScribe, Software and Firmware Is DNA75 ever going to get boost functionality, as was mentioned months ago?
	  Early Firmware and EScribe Suite Discussion Threadgorman replied to David Campbell's topic in EScribe, Software and Firmware Thanks James. Looking forward for DNA75 Boost support. I understand testing it on a less popular platform.
	  Early Firmware and EScribe Suite Discussion Threadgorman replied to David Campbell's topic in EScribe, Software and Firmware Ok. As long as the request for boost function on DNA 75 (not 75C) is clear, I'll patiently wait. Cheers.
	  Early Firmware and EScribe Suite Discussion Threadgorman replied to David Campbell's topic in EScribe, Software and Firmware It's been weeks and everybody here is fully aware that, not being temperature controllable, Kanthal can just be used with a boost function. I wrote this more than once and always referring to the fact that it's available for DNA 75C. Reading the above is quite demoralising. It's not as if I love repeating the same things over and over...
	  Early Firmware and EScribe Suite Discussion Threadgorman replied to David Campbell's topic in EScribe, Software and Firmware Hi John, considering that people have pretty much unanimously stated that they would be more thank ok with the two stage setpoing, for big Kanthal coils, basically, do you think it could be added? DNA 75/200/250 have plenty of power (according to the coil you can reasonably think of using) to have a preheat programmed, as it happens on DNA75C. Please, do not abandon your first clients. The product is working still fine, don't force us to upgrade for the sake of it. Thanks.
	  Early Firmware and EScribe Suite Discussion Threadgorman replied to David Campbell's topic in EScribe, Software and Firmware Yes. It does. As the "author" of that trick (check the thanks in the post), I'd still like having an official solution to this, instead of a workaround.
	  Early Firmware and EScribe Suite Discussion Threadgorman replied to David Campbell's topic in EScribe, Software and Firmware I'm looking for the two stage setpoint, assuming it's the same thing as preheat. Limited to the nameplate max power. I have two DNA75 and I'd like to be able to use preheat up to its specs, for a variable amount of time (as it's already doable with temp measurable wires). Thanks for taking this into consideration.
	  Early Firmware and EScribe Suite Discussion Threadgorman replied to David Campbell's topic in EScribe, Software and Firmware No answer?
	  Early Firmware and EScribe Suite Discussion Threadgorman replied to David Campbell's topic in EScribe, Software and Firmware Could you please let us know if the boost function is coming to DNA75, 60, 200 and 250? And if not why? I doubt it's such a key selling point that you would want to "reserve it" for newer chips. It would be much appreciated if support and new features aren't kept artificially from existing hardware. Thanks in advance.
	By the way, thanks yoseff. I didn't think to do this but it's much appreciated. And thanks for giving me credit. It's a small thing but yesterday, when I discovered people using it, I was a little bit proud. Cheers!
	Glad people are finding this useful
	Out of the blue this is happening. I left the mod charging on my bedside table tonight, woke up in the middle of the night (it happens quite often) and unplugged it. This morning I started vaping and I saw charge at 20%. Since I had to travel all day, I put the mod away and used a different one. Came back home now, attached it to Escribe and Escribe sees it. Now the battery is at 13%. You can see my monitor diagnostics below. I tried different cables and different chargers. What I notice is that: a) The three cells seem balanced. b) There is a *very* little charge coming through the USB cable (0.015A instead of the usual 0.5A). This is not enough to make the bolt appear but it's enough to stop the display from turning off (it sees the connection). I now detach it while waiting for some help. Thanks.
	You can actually "cheat". You load the curve for Kanthal from Steam Engine. You'll see it's perfectly flat, with all the data points sitting at 1.0 coefficient. You leave most of them alone but start raising them by 0.1 after 392F°, 0.1 for every following point. You then select the new material for the VW profile, you instead opt for temperature control, set up preheat to your liking and vape. The circuit will respect the preheat values (I set the punch at 11, so it just erogates the preheat power for the preheat time duration), then, measuring the resistance and seeing it doesn't get higher, it will simply keep on outputting the max power you have set up. And that's preheat for non temperature sensing coils in variwatt.
