Yas786
  • Full Name
    Yaser
    London U.K.
    Lost vape triade, rebel mods 20700 DNA75C squonker
Yas786's Achievements
  1. What theme are you using?? You need to use the default theme in escribe. Then go to profile 8 and make sure the replay box is ticked then upload to device.
  2. Yep hats off to evolv, love the replay update for my dna75c squonk mod. It’s brought a new life into it, not to say that I wasn’t using the dna75c squonk mod before replay but now using it all the time.
  3. Works perfectly fine with replay. Although if you get a check atomiser message on your mod then try it without the beauty ring that goes around the bottom of the atomiser. Doing that will make the atomiser work.
  4. Ok so looks like I’ve finally fixed my issues. Seems like the entheon rda wasn’t playing nice due to it having a removeable beauty ring that goes around the rda itself. Anyhow so I put another SS316L Fused Clapton coil in and rewicked and still same check atomiser message was coming up. So I have a hadaly rda and I put that on with the same coil and voila works like a dream. No check atomiser messages when replaying etc etc. So I threw my entheon in it again and bam again check atomiser messages coming up. So i put my entheon on again but without the beauty ring around the bottom...and it works like a dream. So if anyone is having the same issues I was having, if your atty has a beauty ring then try it again without it. Seems like it was a connection issue, I have a rebel mods dna75c squonk mod and it seems like the mod does not like the beauty ring on it when doing replay. But without it the mod works perfect. All happy now \0/.
  5. Forgive me if I’m wrong here but what makes you think the 250c will do replay on the coils you are having issues with?? Ni80 and kanthal will not work with replay or tc mode. That’s just not limited to the dna75c board. You will have the same problems with a dna250c mod.
  6. Thanks Vaping I’ll give it a go later today and report back.
  7. No help guys?? Been tearing my hair out trying to get replay to work properly. I just don’t get why it’s not working, when I save my puff it keeps saying check atomiser, which I’ve done so many times that I’m all out of ideas!!!
  8. Hi all, long time lurker here but need some advice. So anyhow I earlier updated my dna75c mod to the new replay function. Made sure I defaulted to the evolv theme, also reset my device as well. So profile 8 I’ve enabled replay mode, set my watts to 50 watts and started to vape. When save puff option came up, I clicked that so it’s now replaying as it’s meant to. So my issues are that after a few puffs, my rda gets silly hot and I get the message check atomiser. So I lowered my watts down to 40watts and isn’t as hot as it was at 50 watts. So that’s ok but now after having a few pulls I’m finding I’m getting the dreaded burnt cotton taste. So I make sure my coil and wicks are nice and wet and away I go but again after a few pulls I’m getting the check atomiser message and burnt cotton even it’s only been a few pulls. Im using a dna75c squonk mod with the psyclone mods entheon. I’ve made sure the coil is nice and tight, even took it apart and re wicked with cotton. I’ve got a 4 wrap SS316L 3mm id alien coil. It’s definitely a SS316L coil. Ive turned replay off and vape as normal and it's perfectly fine, no check atomiser message nor do I get a burnt cotton taste even with chain vaping it till wicks are dry. But in replay mode the wicks are wet and as I said a few pulls I get burnt cotton. Any ideas?? It’s not working as it’s meant to really.
  9. That’s the ginger vaped boxer mod if I’m not mistaken. Mike Vapes has a review video up on YouTube and it looks similar if not the same.
  10. Sorry dwcraig I did see that and I was wrong when I assumed it was to do with battery charging :/. Thanks for helping out though
  11. Ok so seems like there isn't an option to put battery % on the screen. All I see or choose from is battery charge % and battery charge Wh. Which i assume is to do with charging the batteries etc.
  12. Oh ok I thought as much as I played with some settings but couldn't change it. I'll see if I can get the battery % showing on my screen. Thanks
  13. Hi all, Just new to these boards so please go easy on me. So got a Triade DNA 200 mod and absolutely love it even though the software confused me a bit this morning when I picked it up. Anyhow I had the Wismech releaux 2/3 which was giving me no end of problems so took it back and got the triade instead. Now on the wismech I could change the battery bar to a percentage ie showing me how much battery life I had left, not that it was accurate or anything. But on the triade is there anyway to change the big battery icon to a percentage of battery left on the screen?? I had a play with the escribe software but couldn't see anything in there pertaining to my question. I mean if it's not possible to do then fair enough. Thanks for any advice/help given.
