Seigfried
Seigfried's Achievements
  1. How is that Cisco 510 working out?
  2. Seigfried
    DNA 250
    250 watts...meh 2 amp charging now I'm interested.
  3. I used 1.1mm stainless steal wire at 24 inches .44 ohms in a single vertical loop. You can get it at hobby stores as picture hanging wire. It looked like an old UHF TV antenna. It barely warmed up at all.
  4. no, it will just be a little cooler. the wire just won't heat up as much under load.
  5. sure, that is what I used.
  6. Thanks, that is better performance than I'm seeing out of my Zippy Compact 1300. Now back to your regularly scheduled thread
  7. Have you run the batt analyzer on the glacier lipo yet What kind of time are you getting out of it?
  8. Battery size specs are 68mm x 30mm x 20mm. Couldn't find one at hobbyking over 1000 mah and I don't know how much extra room you have. Good luck finding a replacement.
  9. That is what I'm understanding from the RC sites. I get 10.8 watt hours out of my 1300 mah batt. which comes out to 75%.
  10. You only get to use 75% of the battery rating. The DNA 200 only allows you to discharge to 3 volts. 75% of 14.43 watt hours is 10.8 watt hours
  11. Most USB cables that come with devices are meant for charging only and don't have the data lines installed.
  12. Looking at the milling around the 510, I don't think its a wrap. I'm drooling on my keyboard.
  13. Yep, ya gotta watch out for those charging cables.
  14. Put an old dripper on it and run the wires to the posts.
  15. Nice lookin box Aussie
