flem
Everything posted by flem
I have a DNA200 and a SDNA75 and i have had a lot of problems with fluctuating ohm when using SS316L from UD. I resently bougt a Serpent Mini and at the same time some Geekvape 316L and I do not have any problems any more with the SS316. Steady as a rock in Escribe and the vape is smoth and just as it should be. At first when I got my SDNA75 and the new escribe software I was very disappointed, because I did not get the Vape that other users wrote about still the same crappy up and down with the SS wire, but after I use the Geekvape I really get a great stady vape. The only prob with the SDNA75 is that it jumps out of profile when left for langer time idle. I get a horrible dry hit when using it after its been idle for a couple af hours, but now I now why so I just change back to the profile I have on the attached tank, but other than that the 75 is also a great chip, but I changed some settings It came with Daniels settings, but some of them did not suit me.
?????Escribe?????mod????????
Mod says its at 400deg but no steam coming off the coils
flem replied to jsheeler's topic in DNA 200 and 250
Hi. Try reboot the device in escribe under tools -
flem replied to David Campbell's topic in EScribe, Software and Firmware
good point i just looked and noticed as well they took it away or i just can't find it. the box that lets you input your own TCR value is no more? that's a bad move. it was so nice to be able to just throw a tcr value in and call it good. i was hoping for a tcr adj from the mod itself, TBH. like joyetech, yihi, or sxk.[/QUOTE] You can change the TCR under the Materiel tap. Mark one of the material and you get the values up and can then change TCR there. -
Hotcig have now made a battery inclosure that takes 2 x 18650 batteries and they also have a 1300mah lipo battery inclosure. See more her http://www.alibaba.com/showroom/hotcig-dx200-battery.html
Hi. It is closest to TI. Yes you can use it in power mode just like SS, but this wire is just like Kanthal to work with. The best place to buy this Nife52 is at a german shop and they are fairly cheap and ship very quickly. They call it Nife48, but it is Nife 52. I will suggest you searc for Nife52 coils on our friend Google and you will get many links which is about this great wire. The german shop which also have English is here http://www.zivipf.com/epages/63862298.sf/en_GB/?ObjectPath=/Shops/63862298/Categories/Heizdraht/NiFe48 good luck and have a great day.
After a long time with the SS and many probs just like you I now only use Nife52 wire. It gives a better flavor than SS and is much easier to work with, much like Kanthal and the biggest pros are that the DNA200 CVS from Steam works out of the box. With this wire I get a steady temp reading , so I am a happy DNA200 user now.
Hi. That is because you dont have the latest Escribe installed. EScribe version is 1.0.35.2 /topic/65933-topic/ enjoy
In Escribe under themes - right down the buttom to the left you can change it
You can get it here http://www.zivipf.com/epages/63862298.sf/en_GB/?ObjectPath=/Shops/63862298/Categories/Heizdraht/NiFe48 This is a good vendor and they ship worldvide
I usually use Celsius on my Mod, but I tried to set the temp as fahrenheit an got a much much better vape / flavor on the same coil. its a 7 wrap spaced 316L coil coming out at .05 and I was vaping this at 248 degrees celsius, but changed it to 470 degrees fahrenheit. Can that be because the chip makers standard is fahrenheit? i am running this on a Steam Crave so easy to change coils, so later I will try to make a Titanium coil and also change the profile on this to fahrenheit and see if I get the same difference.
Gearbest is well known for trying to discourage there customers to persude the refund claim after you make the video they will find something else for you to do. If you check the Internet you will find that 50% of there customers is dissatisfied with Gearbest. When I buy from China shops I always use Paypal, because I then have some security and help if things go wrong.
I have a Hotcig DX200 and it takes 35 minuttes to charge the batteries when I use the wall charger that came with the Mod and I bought a spare battery from Hotcig. I know there are some post and reviews out there that state that the Hotcig is junk, but mine have been working without any probs all the time including the batteries and charger. I have had it now for 2 months. I dont know how long it takes by USB as I never charge that way.
I am running a 0,285ohm spaced coil in my Goblin mini. I have tried the version 4 and 3,125 and the version 3 of yours and i have settled with the version 3. I get great flavor, but some sizzling on the coil also after I stop vaping? I have the temp set at 235C and 35W and still some fluctating when i test in device monitor. I will try the cotton suggestion of yours when the tank is emty I may have to little cotton in there. Is it better to run a higher ohm with the SS? thank you
I have followed this guide and it works every time. http://blog.craftvapery.com/joshs-definitive-guide-to-temperature-control-with-titanium-wire/
No this is a new 75watt Mod which they also claim can meassure how much juice you have left in you tank
We are with the DNA 200 working with the most advanced TC chip and the a Chinese company comes with a new TC mod and claims it can handle all kinds of wires in TC mode and it can even tell you how much e liquid you have left in your tank - . If I remember right I think they made another Mod claiming the same thing with the wires, but Google this and have a look - ijoy solo mini.
I had the same problem with the TVF4, because this tank really gets warm also when you just vape normally - no chain vaping. I dont use the tank anymore, because it really gets hot and I think its a big fault when a tank get this hot with stock coils.
Yea its a great vape with the Titanium when we have a working coil. I had many problems with the SS until I found this CSV file http://dna200.de/kurven_draht/edelstahl-306-v4a/ if you use 316L is it the buttom download. Enjoy the great flavor of SS
I built my Ti coils as contact coils and that works great on the DNA 200 here is alink to a contact TI coil build http://blog.craftvapery.com/joshs-definitive-guide-to-temperature-control-with-titanium-wire/
Wait,same thing happened to me! How exactly do I do this? I am running VB on an iMac...so where do I find this "tools" you speak of? Ok, I found it, but whenever I try to press "ok" it keeps saying "device is not connected"...so is my mod dead?[/QUOTE] If an update fails on a VirtualBox setup, you may have to do the manual update via a real PC. I had a failed update that I could not resolve with VirtualBox but did get it to work with a PC. Make certain that the DNA200 is plugged in while booting the PC.[/QUOTE] My device is plugged in, however, since I can't turn it on and it shows no signs of life, it is not detecting it. It is devastating and Gearbest is not being very cooperative. They are really screwing me over. I've been contacting them since last Tuesday and have gotten nowhere with them. [/QUOTE] Get in contact wit the sales rep on this forum http://www.thailandvapers.com/forums/gearbest.166/ She is usually very helpful. And when you contact them tru a forum they are more responsive, because many other people read those post too. Good luck
I also have the Hotcig DNA200 and I just bought a spare battery from Hotcig and then it takes 10 second to change and you are good to go again.
I can follow your guys. I have 4 other Temp Mods, but After I bought the Hotcig DX200 I only use one of them and that is the Joyetech Evic, because I always have 2 different juices to vape. The Evolv DNA 200 make suchs a big difference in the taste of my liquids, so i am thinking of getting another Mod with that chip. There is a huge difference in flavor when I use my tanks on the Evolv chip compared to the other temp Mods I have, Maybe it is the preheat or just the chip that is really doing its job compared to the others
Hotcig DX200 stopped working after less than 2 days use.
flem replied to Ramrod's topic in DNA 200 and 250
Thank you very much
