flem
    China
    DNA200
flem's Achievements
  1. I have a DNA200 and a SDNA75 and i have had a lot of problems with fluctuating ohm when using SS316L from UD. I resently bougt a Serpent Mini and at the same time some Geekvape 316L and I do not have any problems any more with the SS316. Steady as a rock in Escribe and the vape is smoth and just as it should be. At first when I got my SDNA75 and the new escribe software I was very disappointed, because I did not get the Vape that other users wrote about still the same crappy up and down with the SS wire, but after I use the Geekvape I really get a great stady vape. The only prob with the SDNA75 is that it jumps out of profile when left for langer time idle. I get a horrible dry hit when using it after its been idle for a couple af hours, but now I now why so I just change back to the profile I have on the attached tank, but other than that the 75 is also a great chip, but I changed some settings It came with Daniels settings, but some of them did not suit me.
  2. ?????Escribe?????mod????????
  3. Hi. Try reboot the device in escribe under tools
  4. good point i just looked and noticed as well they took it away or i just can't find it. the box that lets you input your own TCR value is no more? that's a bad move. it was so nice to be able to just throw a tcr value in and call it good. i was hoping for a tcr adj from the mod itself, TBH. like joyetech, yihi, or sxk.[/QUOTE] You can change the TCR under the Materiel tap. Mark one of the material and you get the values up and can then change TCR there.
  5. Hotcig have now made a battery inclosure that takes 2 x 18650 batteries and they also have a 1300mah lipo battery inclosure. See more her http://www.alibaba.com/showroom/hotcig-dx200-battery.html
  6. Hi. Go here and choose nifetal52 and download http://www.steam-engine.org/wirewiz.asp#
  7. Hi. It is closest to TI. Yes you can use it in power mode just like SS, but this wire is just like Kanthal to work with. The best place to buy this Nife52 is at a german shop and they are fairly cheap and ship very quickly. They call it Nife48, but it is Nife 52. I will suggest you searc for Nife52 coils on our friend Google and you will get many links which is about this great wire. The german shop which also have English is here http://www.zivipf.com/epages/63862298.sf/en_GB/?ObjectPath=/Shops/63862298/Categories/Heizdraht/NiFe48 good luck and have a great day.
  8. After a long time with the SS and many probs just like you I now only use Nife52 wire. It gives a better flavor than SS and is much easier to work with, much like Kanthal and the biggest pros are that the DNA200 CVS from Steam works out of the box. With this wire I get a steady temp reading , so I am a happy DNA200 user now.
  9. Hi. That is because you dont have the latest Escribe installed. EScribe version is 1.0.35.2 /topic/65933-topic/ enjoy
  10. In Escribe under themes - right down the buttom to the left you can change it
  11. You can get it here http://www.zivipf.com/epages/63862298.sf/en_GB/?ObjectPath=/Shops/63862298/Categories/Heizdraht/NiFe48 This is a good vendor and they ship worldvide
  12. flem
    SS316L Help
    I usually use Celsius on my Mod, but I tried to set the temp as fahrenheit an got a much much better vape / flavor on the same coil. its a 7 wrap spaced 316L coil coming out at .05 and I was vaping this at 248 degrees celsius, but changed it to 470 degrees fahrenheit. Can that be because the chip makers standard is fahrenheit? i am running this on a Steam Crave so easy to change coils, so later I will try to make a Titanium coil and also change the profile on this to fahrenheit and see if I get the same difference.
  13. Gearbest is well known for trying to discourage there customers to persude the refund claim after you make the video they will find something else for you to do. If you check the Internet you will find that 50% of there customers is dissatisfied with Gearbest. When I buy from China shops I always use Paypal, because I then have some security and help if things go wrong.
  14. I have a Hotcig DX200 and it takes 35 minuttes to charge the batteries when I use the wall charger that came with the Mod and I bought a spare battery from Hotcig. I know there are some post and reviews out there that state that the Hotcig is junk, but mine have been working without any probs all the time including the batteries and charger. I have had it now for 2 months. I dont know how long it takes by USB as I never charge that way.
  15. flem
    SS316L Help
    I am running a 0,285ohm spaced coil in my Goblin mini. I have tried the version 4 and 3,125 and the version 3 of yours and i have settled with the version 3. I get great flavor, but some sizzling on the coil also after I stop vaping? I have the temp set at 235C and 35W and still some fluctating when i test in device monitor. I will try the cotton suggestion of yours when the tank is emty I may have to little cotton in there. Is it better to run a higher ohm with the SS? thank you
