speed4mee
Everything posted by speed4mee
Don't fire the mod when you are shorten the atomizer!
Another board that wont charge the battery
speed4mee replied to John connor's topic in Batteries and Charging
Try to align the batteries properly -
I think to show the current is useless. I switched from Volt to Last Temperature
I think you've made something wrong. You use a Reuleaux that i can see from ECF. Be sure to run the latest EScribe Software and load the latest Firmware according to: http://www.wismec.com/product/reuleaux-dna200/ You can also load the setting file. First you can control the resistance of your atomizer with Atomizer Analyzer. If you change settings don't forget to klick Upload Settings to Device. Another method is to go to Device Monitor to control your Settings. Try it and be Patient, it's worth
Did you checked the balancer ports?
Why did you swap the lipo batt?
Feature Request: Puff time cutoff option
speed4mee replied to slickerxcuh's topic in EScribe, Software and Firmware
I think the 20s puff cutoff is a bit too Long. I would prefer 10s, but i can't change this in EScribe -
Gold coating over stainless steel is the worst for the mod resistance. I prefer my brass connector #1818, no issues Are the threads also goldplated?
Set Screen -> Charging Brightness to 0%
Feature Request - Escribe software
speed4mee replied to KTMRider's topic in EScribe, Software and Firmware
What i mean is a live view from the screen that isn't attached A software substitute for the missing display. -
Is it possible to show the actual screen in the Device Monitor. It's useful for a defective or not attached screen -
I've just inspected my dead display with a microscope. By bending the ribbon cable near the display some wires are broken due to the sharp edges of the glass. This was the death of my display. Which can also apply to the Hana V200. The sharp bend, near the glas, is also good to see in the photo from KTMRider..
I've just inspected my dead display with a microscope. By bending the ribbon cable near the Display some interconnects are broken due to the sharp edges of the glass. This was the death of my display.
I also take a beta unit too and would assemble it myself
yeah, bolts and nuts
You can also use nuts, so you can adjust the hight according to your liking
Mod assmbled but screen not working
speed4mee replied to mbuzzar1's topic in Installation and Assembly
Thank you, John -
No other display available I think i've bend it too much by assembly. The cable is right fitted. -
I've made a transfer from my function mod (see Let's see your 200's! #55) to my new aluminum case. Unfortunately my display is dead The mod fires, all functions via EScribe are ok. What can i do?
