Stock 30 second timeout is ridiculous At 40% brightness will be hard to see in bright sunlight Adding a screen to my okr 50watt mod make me go from 3day to 2 day
Would be cool but maybe hard to implement And find kind of silly having the watts on big number on the charging screen Would much prefer to have 6 custom field to show all 3 cell volt and total volt , USB volt and current
Can you add the option to select number off click to lock the device to 3 click And when you lock to change temp or select stealt mode can it unlock after confirm
On the MOD tab of Escibe you will see: The Ohm Lock Range is what percent of resistance change will trigger the "New Atty" question. In the above case of 25%, if the atty was originally at 0.1 ohms then 0.075 or 0.125 would trigger the question. It the reverse if it more then 25% it will not ask new coil question
Yes it will work if wired correctly But reverse batt protection look more complexe need like 8 mosfet to work for removable batt 3x18650 is pretty big and heavy lipos pack are way smaller + round cell = lot off wasted space
