Bobw1951
About Bobw1951
  • Birthday 11/28/1951
  • Full Name
    Robert Joseph waller
    London, UK
    DNA200
Bobw1951's Achievements
  1. I didn't find it bad, but wouldn't really rate it, there is definitely better around, in other tanks I tend to use either Muji or Cellucotton rayon, but I don't waste anything so have used any cotton that comes supplied with tanks etc
  2. Had mine set to 400F & 50w - tank used to get quite hot but it didn't burn the cotton that came with it
  3. For the Altus tank I just used the Steam Engine values for Tungsten - seems to work okay
  4. Ohms Law V/R, P/V or sq.root P/R
  5. On mine I have 6 Triton v1s using the prebuilt SS & Ni heads. 2 Aromamizers using dual Ti & dual veritcal NiFe30, a Triton v2, an Atlantis v2, a Serpent & and a Guo Vape Altus with the Tungsten head
  6. You can use the down (-) button to go the other way instead of just the up (+) once you get to the 4th profile
  7. Just did an analysis @ Room Temp 73.58F Some of the figures in above comments look quite crazy, the test runs for 3 hours 40 minutes and the mod must be left alone whilst the test is being carried out. The 1st hour is to allow the Temp to settle, the next charges @ 0.50A for 1 hour, then cools for 1 hour, it then does 10 minutes each of charging & cooling @ 0.10A and 0.30A before giving you the results to accept & then upload to your device
  8. If you got it from Vape Geek like I think you did, then it's already done. If I remember rightly, the firmware needed updating if you are using the latest eScribe, but eScribe will tell you that
  9. Does that include the pre-made coils that the Triton & Crown uses, because if it does, then I respectively suggest you try them, because those definitely work under TC, I tried some 317L from a company here in the UK and I could not get it to work under TC, finally giving up, and refuse now to buy anything from said company, I now prefer to use Ti or NiFe30 from Stealth Vape, and I think the reason they do not sell SS is probably because of the problems getting it to work correctly or they do not think it is safe to use, unfortunately they are not replying to enquiries about it.
  10. I've had that a couple of times - but when I have pressed the upload button a second time it has always worked.
