I haven't had a chance to run the analyzer yet, but I'm curious about when the analyzer terminates the test. Does it simply cut the test at a preset voltage (as measured under the load of the test)? If so, what is that voltage? If it's using voltage under load to terminate the test, I presume it would be best to run the test with a load that is representative of your typical atty. EDIT: Also, are the SOC curves based on voltage at rest or voltage under load? I presume it's the latter, since the data would be gathered by the battery analyzer while the cells were under load (unless it periodically unloads the cells, allows them to recover, and samples their resting voltage). If that's the case, I'm also curious about how the battery meter works (since the resting voltage of the battery will be higher than its voltage under load). Is the battery meter basing its estimate of SOC on the voltage of the battery when it was last under load (i.e., during the last puff), or is it basing it on the resting voltage at that moment? If it's the latter, then it seems to me that it would always be overestimating SOC (assuming the analyzer doesn't periodically sample resting voltage throughout the test).
