I just installed your latest version on my DNA75C. I have a question; when you enable Replay in the settings for a profile that uses temperature control it no longer allows you to set the watts only the temperature? Could you explain is there a way to set the watts in TC with Replay enabled? If not, then what is it then using for the watts setting?
I like this theme very much. I am using it on HCigar Vt75D. I am little confused when using this in vw wattage only mode it is still showing a temperature setting on the display? I would have thought that if you were in a non-temperature mode such as Kanthal or Nichrome it would not show any temperature setting in the display? Other than that issue the theme is wonderful and very easy to read.
I had a similar problem and solved it by changing the csv profile for 316L. I downloaded from Steam and that was not to my liking so I looked around on the forums and found one that worked for me. If it is a new build everything is tight and clean then I would try a different profile.
