Brad S Ruttenberg
About Brad S Ruttenberg
- Birthday 03/17/1959
Full Name
Brad S Ruttenberg
Location
memphis tennesee
wismec dna 200 and the vapor shark dna 200 vapor shark 75 think vape finder 250c
Brad S Ruttenberg's Achievements
i was told that sit tight and wait for a firmware update.. or i could send mine in for testing to help with their forensic process.. but it would most likely be a firmware release.. so that being the case ill just wait for the update
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
Think Vape 250c Thermals Mod res and a couple of battery csv's
Brad S Ruttenberg replied to Jetro's topic in DNA 250 Color
im not suporised yours are different i have questrions about the thermals posted above the poster didnt answer in a way that gives me comfort about the numbersand or might indicate english is not his/her primary langauge as for ss finish versus oher finishes it would change numbers slightkly but not hugely no i suspect the numbers for the thermal were not run properly above.. or are not for the think vaper finder 250c -
im having same issue intermittent think vape finder 250c Evolv DNA 250 Color Device Information Serial Number VFEN WFPD ODZM Production History Thursday, May 3, 2018, 9:42 PM Board programmed Serial Number: VFEN WFPD ODZM Firmware Version: 1.1 SP33.2 INT Revision Code: 311103398 USB Vendor ID: 268B USB Product ID: 0419 USB Product Version: 3.0 got a ticket with evolv.. sometimes it wakes fine sometimes the screen doesnt wake but it will fire.. and sometimes it wont wake.. error waking or scrn staying blank but firing approx 105? and batty type or charge doewsnt seem to affect anythng nor does theme nor rebooting etc
- 186 replies
- lost vape
- paranormal
(and 1 more)
Tagged with:
Okay h3,does. But that doesn't really affect my question I mean it's possible he does but my concern is more with the weird trickle amperage or can I use the results from somebody else who has the same mod I do even if the ambient temperature they tested them in was 75.2 degrees cuz I could plug in those values and be much much closer than evolve defaults but there's no way when you plug in values manually to indicate what the ambient temperature the test was run at you know like I said whether the guy at the video said half charged or not is really an incredibly tangential issue
i will try it with 1/2 charge... and let you know... and no he didnt but the video comments i was refering to were his comments about some chinese mods having a trickle amp.005ish and never just reaching 0.000 which throws off thermals etc and makes the diagonostic test hard to run cause it doesnt stablise the temp back down over 30 min...(from the heat up start...)..etcid assume the .003amp trickle wouldnt be a huge variance? if i could get the diagnostics to complete which it wont since it expects and needs to see 0.000 amps.. .. also it occurs to me that since the .003-005 amp trickle is a characteristic of my mod.. having it figured in the case analyzer would be okay .. iuf i could actually get the case thermals test to run.. and finish which is the probklem right now it wont cause it expects to see 0.000amps and expectsa the case to drop somewwhere close to ambi temp.. right now cause of the trickle charge it fluctuates
sorry for the chape seatrs comment i got a email that someone had replied in a way indicating profound lack of understanding of the issues i was having i edited the comment as the comment it was refering to doesnt seem to be on the thread.. and it was out of frustration and not fair.. now .. i might start an evolv ticket thank you for the info.. ..and no i actually did it when the batt was close to full... .. it might make a difference so ill wait til the batt is half discharged and THEN ill re try case analyzer maybe the trickle charge wont happen if its not nearly full... ill try again and post whether i had success with half drained batts or.. if it was the same result and if i needed to start an evolv ticket
did you have amp trickle?? when i tried running case analyzer myself on my finder 250c the green power line fluctuated tween.002 and .004 and would occassionaly go to 0.000 but then fluctuate again indicating a very very small amp charge reading and that would affect the case temp stablizing and reaching ambeint temp in 30 min*first partt of case analyzer test.. i wondered if you had the same thing?? is that just part of how the mods made? or is there something wrong with my chip and should should i contact evol for rma? -
of course i have a backup copy .. I have a .003 amp trickle its not enough to charge but it is enough to keep the mod from ever getting a good case thermal.. .. as theres a continous low amp trickle and a consistent temp inc /fluctuation because of it as the gentleman mentions on this its enough to keep the temp of the case skewed and elevated... so is that a problem with the board? do i talk to evolv? it should be 0.000 amp when running case analyzer
I didnt run the case analyzer someone else ran it on their mod and posted values the room they ran at was 75.2F i can not run it on mine as it trickle charges shows a .0002-0004 continuos charge or temp change due too charge ... so since i cant run it andf the data i have was ran at a much higher room temp can i use the nubers?
nevermind i guess i cant run em i have a .003 charge leak so i never stay at 0.000 for the test to run.. so my room is approx 70.00 maybe 69.5 can i plug in the values you got at 75.2f?? o how do i tell it those values are for 75.2???.. the only time it ask for a room temp is when i try to run the case analyzer and i cant run it due to low level charge leak -
can i use these case thermals since my room temp is 68f?? or should i run it myself? -
thanks the settings are great!! does anyone have a CSV for 3* lg hg2 -
will this work for my think vape finder dna 250c 300 watt??(its 3 LG hg2) so im guess its exactly the same ?? and what do i set the soft cut off for??(default with the 250c is 2.,7v ..it looks like the csv assumes a cut off of 3.02v? is that correct?? im happy to use 3.02 as my soft cut off as thats a bit safer as the batts age if the file above ownt work well for the think vape finder 250c cxan someone get me one that will its a 3s lg hg2 set up
Hg2 battery profile csv file
Brad S Ruttenberg replied to Aalmosawi's topic in Batteries and Charging
d ive got a think vape finder dna250c 300w *so it has 3 LG HG2 batts .. so im guessing i want the 3s lg hg2 battery profile?? and not the single one??
