Mangiman
Everything posted by Mangiman
  1. Can i use the same settings wire from my dna 200 in my dna 75?
  2. Can i use a 6400 MAH 1s LiPo with 90c or should be below 90c?
  3. Anybody knows where to get a LiPo 1s with xt60 connector and does the micro usb port on board will charge it?
  4. This new chip runs on 3s LiPo or 2s or 1s ???
  5. Hello DNA's users, i built my own DNA 200 about 4 days ago, i used my own mitec switchs up/down and Fire, last night my dna box started firing itself, i had to remove the battery so it will stop showing check atomizer after i removed the atomizer, so far i check all three swichts with a multimeter and works fine, the problem comes back when i connect the battery starts on itself and fires itself.... Any help will be appreciate!!!!!
  6. Hello DNA's users, i built my own DNA 200 about 4 days ago, i used my own mitec switchs up/down and Fire, last night my dna box started firing itself, i had to remove the battery so it will stop showing check atomizer after i removed the atomizer, so far i check all three swichts with a multimeter and works fine, the problem comes back when i connect the battery starts on itself and fires itself.... Any help will be appreciate!!!!!
  7. Hello DNA's users, i built my own DNA 200 about 4 days ago, i used my own mitec switchs up/down and Fire, last night my dna box started firing itself, i had to remove the battery so it will stop showing check atomizer after i removed the atomizer, so far i check all three swichts with a multimeter and works fine, the problem comes back when i connect the battery starts on itself and fires itself.... Any help will be appreciate!!!!!
  8. Hello DNA's users, i built my own DNA 200 about 4 days ago, i used my own mitec switchs up/down and Fire, last night my dna box started firing itself, i had to remove the battery so it will stop showing check atomizer after i removed the atomizer, so far i check all three swichts with a multimeter and works fine, the problem comes back when i connect the battery starts on itself and fires itself.... Any help will be appreciate!!!!!
  9. Thanks Alistairs!!!
  10. I have a box with a 18650 mah 3s 100c lipo thats the one i need to get the same settings to load it in a hana v200 with 950 mah 3s LiPo. How can i change just the battery specs from the settings that i want to load??? Can it b possible?
  11. Thank u soo much!!
  12. Any body knows how to copy the settings from one dna chip to another ?
  13. Any body knows how to copy the settings from one dna chip to another ?
  14. @Mad Scientist Thank u soo much!!!! I got 4 of those and i was wondering if it can be useful....
  15. Anybody knows what happened if i install a Maxamps 3 s LiPo 11,000 11.1v in my dna 200???
