Lance
Everything posted by Lance
Sorry for jumping in on the thread. Does any one happen to have a csv for a triade 250 with samsung 30q's? Thanks
Very nice.
Yeah Wayneo, I have had a DNA 200 for over a year but it became a paper weight as i couldn't get it to do what i wanted and crap battery life so gone for a triade so i can change the batteries.
Just a bit of a enquiry. Just ordered a Triade DNA250 and bought some Samsung 30Q will they be ok with this device? Thanks Lance
Mine is a Hcigar dna 200 so its not a Lost Vapes issue quite a few people have or have had the same problem. I also did a SS316L clapton build in a Boreas and Steam Crave Supreme and also Ijoy Tornado nano they all go funky on the DNA but on the Ijoy LUX + Joyetech + Fuchai + Istick 200 they work fine in temp mode. I also sent the DNA back thinking is there a fault but nope no fault found. It works great as a power only device.
Exactly the way i have to do it on the DNA, But to be honest i haven't used my DNA in over 6 months because of this reason it has become a paper weight.
Just a quick one Can you dry burn NiFe52 coils?
Yep i get that in my HCigar VT200. Pain in the back side
I put the 430 and 304 on from steam engine but found the 304 worked better for me. I still use 430 csv as well in a different profile but just switch between.
I got some SS430 and to be honest i had a better vape of it than SS316L and not much messing either. I used the 304 CSV of steam engine and changed the TCR in escribe to match SS430 and its been pretty good to be honest for me any way. Some one will be able to guide you in a better direction on here i hope Lance
with the VT200
Yep i have the same problem so to speak, and i think a few others.
As a test i just did a dual 6 wrap twisted NI200 28g. On a ohms tester and another mod it comes out at 0.08ohms but when i put it on the VT200 it shows 0.01 and in escribe it shows 0.044 with atty analyzer. Raw ohms = 0.044 Normal ohms =0.017 Cold ohms = 0.015 And also hits tp in a split second.
I still get "unsupported file format". Weird but hey ho.
Hello Vapingbad Yeah it was a zip so i unzipped it and there is a file with extension ecig (HCigar VT200.ecig) that is what it is. Also re downloaded 3 times still the same. Cheers Lance
I get unsupported file format from that ecig profile. When i try to upload it to the vt200[/QUOTE] You probably have a different globalisation setting for number formats, you can temporally change it to en-US to load the file.[/QUOTE] Just tried changing to EN-US and still "unsupported file format"
Yep i have and it works. But in order to get it to a ohms that work its hit and miss as i have to fire it in kanthal for a split second then take the tank off and back on again and if im lucky then the ohms will have raised 0.02 to 0.03 and then lock it and it works, But am i getting the correct TC or ?
Ok another build SS316L 24g dual 11 wraps 2.5mm on ohms meter it comes out at 0.40, Then when i put it on the VT200 it registers 0.37 but it does fire but it hits TP and doesn't go higher than 20w and cold vape not much vapor either. This is with a UD Bellus and Aramoriser RDTA. So if i take the tank back off and put it back on the ohms will go up by 0.04 to 0.41 and then fires with a lovely warm vape.1 But when i leave the tank for say 10 minutes and go back to it, It has gone back to 0.37 and back to hitting TP with in a second. Tried 4 different CSV files inc the ones from Jaquith and wire wizard. On power only mode its perfect. Lance
This is where i got my SS316L from http://www.wireandstuff.co.uk/products/SS316L-Grade-Stainless-Steel---0.5mm--500-Micron---24-AWG--254.html#SID=88 Lance
Hello I did the free upgrade from Windows 7 x64 to Windows 10 X64 and zero problems with Escribe and my Hcigar DNA box. Lance
Looks like the V2, But not certain.
I have to do the same thing as what Riup does, Its weird. If you can get your coil to warm a little i.e set it to Kanthal (low watts) and do a couple of pulses then go back to your Titanium Preset and it will show the ohms has raised a little you will get vapour and taste. Dunno why but it just is.
