protovapor
Everything posted by protovapor
Got an older dna250 board that refuses to skip the production charging test, and also refuses to pull more than .7a from the computer's USB port, so it never passes. Original programming date sept 2016, while my other 2017 boards skip the charging test fine. Also as part of testing I put in SP9, which causes dna250s to bump to 1.100+v bandgap and fail production. Reverts to 1.02ish when i revert to SP5.
People should not be punishing companies for complying with the regulations. They are doing the right thing whether you think the FDA is doing the right thing or not. That said, in the aforementioned example $10 seems excessive to comply with the letter of the law.
Keep trying to force firmware updates, have heard of someone having to do it 3x to get it to "take"
And profiles are a great feature!
you may want to doublecheck the connections to the fire switch and/or the quality of signal from the switch. if need be, a filter capacitor may help.
meter the battery pack while it is disconnected from the board. check what voltages you are getting at the various pins on the tap
Do you have a missing component? EDIT: Check your tap socket closely for soldering, if there are any bad solders there it will cause screwy readings.
Think I bricked a board. Error codes in Escribe?
protovapor replied to TS12000's topic in Report a Bug
If I may fix that link, the listing is here: http://www.protovapor.com/product/evolv-dna-200d-retail-box/ -
Good one to check, in our experience a bad solder at the tap socket can produce weird results like this.
We try to ship within 1 business day. If you ordered now it would go out tomorrow (Thursday)
We are in Hawaii, our mailing address is on the Contact Us page of the website.
Hi there, the preorder listing was for the time before they were allowed to be shipped by Evolv. Now that they can be shipped, the linked listing applies.
they are available now from various evolv resellers ... cough
Issues connecting to eScribe, through a powered USB hub
protovapor replied to SSV's topic in Report a Bug
It will switch even if being monitored... until it is fired of course -
Yes verified on a bare board as well as on test mods. Do you have the screen set to be on (brightness >0) during charge? -
[QUOTE=SSV][QUOTE=John] There isn't a way to force charge display, but you can put charge parameters on the main display if you're interested. [/QUOTE] John seems to be confirming what my test board is doing....@protovapor [/QUOTE] There is no command to immediately make it switch to that mode, however it will switch normally based on your time parameters. To my understanding, it switches after "active time" and "idle time" settings both elapse. If you set both of those to a very short time you can sort of get it to switch on demand. -
The board switches to charge display mode normally while connected to escribe ... -
Ah yes it does seem one of the resistors(?) is missing from the array on the right. John this is one of ours, how best to handle the repair or replace?
