copyman
Everything posted by copyman
  1. I'm sorry James - no change with the new service pack. Do not worry - there are important things to fix - inscriptions are not the most important. Here it's Escribe 2.0, Escribe 2.0 SP1, Escribe 2.0 SP2 ... Best Regards Milen
  2. Yes - Translating the forum is good - I can not see mistakes and some crunching messages
  3. Hello James, Interesting ... in EScribe 2.0, the new strings are visible in Bulgarian, however, after update in EScribe 2.0 SP1 are in English
  4. I'm sorry for my pass, but after the changes the translation is not displayed again ... EScribe.po
  5. Hello, I'm sorry James but the translation is done and the messages in the window do not change - they are still in English .. Here's the added translation: Best Regards Milen EScribe.po
  6. The bulgarian translation for Escribe 2.0 is made. EScribe.po.zip
  7. The translation for Escribe 2.0 is made. I use the case to request: the text of the "atomizer analysis window" is not included for translation. If it can also be included in the translation file, because here is very important information about pure understanding of cold ohm, nominal ohm ... Please ... Milen EScribe.po.zip
  8. Hello, I'm ready with the new translation in Bulgarian - where do I put it? Here or in "Categories> Translations"
  9. Hello James, And I thank you for your lightning response. We do what we can to make popular your wonderful product! Milen
  10. Hello James, Sorry, my mistake - I use a Russian translation because it was more convenient for me. Bulgarian has two forms of plurals for numbers "Plural-Forms: nplurals=2; plural=(n != 1);\n" . Quite rightly in translation missing msgstr[2] . I fixed the file in my first post. Thank you for your note ... Milen
  11. Sorry for the the impertinence, but to ask - Does expected soon to appear aluminum case (box)? Customers do not like plastic 3D Printing ...
  12. After JQuerty colleague to present my Bulgarian translation for EScribe. I will copy his writings, because it is the same. I attach the archive with the translation; all you should do is to unzip it, and then to put the file with the translation into the folder "en", replacing the same-name file. [CODE] C:\Users\%UserName%\AppData\Roaming\Evolv\EScribe\Languages\en [/CODE] Open the “en” folder, and put my file EScribe.po into it, replacing the same-name one. Another way to get to the folder if you did not enable the view of hidden system folders: Enter the EScribe menu: Help-> About, press 7 times on the logo Evolve and then enter the menu Tools-> Open Languages Folder, like this you open the folder with the translations. I try to give similar meanings of words, if there are errors please be excused. You can write me an email: admin@smoking-maniac.com or leave a message here. EScribe.po.zip
  13. Yes - it's working fine
  14. For me the last and the penultimate version of EScribe work without problem. Windows 10 Pro / 64 bit, upgrade from Win 7 / 64 bit Ultimate, parallels virtual machine.
  15. Hi guys, Here's my mod and - with 950 mah battery Turnigy. The box is a simple 3D Printing, unfortunately SLS (laser sintering) technology is quite expensive. Recast is little the original box for these connectors which I use. Now I again rehandle box like a little expand it (2 mm) and do another back cover for 1300 mah battery. The back cover is extended by 7 mm. The idea is to be able to change only the back cover for the large battery. Two of my reviews for DNA200, did tests with load 200W, unfortunately speak Bulgarian language ... [video]https://www.youtube.com/watch?v=g3AdahSw8lk[/video] [video]https://www.youtube.com/watch?v=_dkxbx-SqPE[/video]
  16. I think that this battery will fit and it's very popular - Turnigy 950 3S at least in Europe ... 72x25x20 25C / 50C 950 mAh
  17. Everything is working normally ...
