copyman last won the day on September 8 2025
copyman had the most liked content!
About copyman
- Birthday 11/12/1962
Full Name
Milen Cholashki
Location
Bulgaria
I have all DNA boards :)
copyman's Achievements
Version 1.6
477 downloads
Information: The theme is based on my previous themes. It works on DNA75C, DNA100C, DNA250C, and in DNA75C/DNA100C does not operate "Power bank" mode. Supports replay. Supports the new Season Mode feature - Works only with Escribe SP45 and firmware 1.1 SP 55.1 On the idea of vapingbad - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution. Preheat: ***************************************************************** Preheating has several states: 1st is when preheat is on, 2nd is preheat off, 3rd is dropped out of temp protection. 4th is TP-enabled=false, 5th is TS-Material=false. This is how the conditions are set: The TP icon: default shows on image, atty\temp-protect-enabled=false as the condition for showing the off image. atty\temp-sensing-material=false also for showing the off image. Text status: default shows "PH" for preheat atty\preheat-enabled=false shows "---" atty\temp-protect-enabled=false shows "PWR" in yellow atty\temp-sensing-material=false shows "PWR"in yellow atty\temp-sensing-dectect=false shows "???" in orange (tested with an ss coil using a NI profile) Temp Field: atty\temp as default atty\temp-protect-enabled=false shows diag\atty\voltage atty\temp-sensing-material=false shows diag\atty\voltage ***************************************************************** Extras: In Lock Screen down: Current in charge or root temperature in non charging mode. When using a power bank, an icon is displayed. In Main Screen two resistans: locked ohms and life ohms. In Main Screen right to Power: temperature of board or output voltage in VW mode. In Main Screen right to Temperature: Temperature ot last puff In Main Screen top: The name of the profile below is the material used In Battery Screen: Below is shown what current is the charge, and the displayed power indicates whether the fast charge is on: normal charge - 7.1 watts / fast charge - 13.2 watts (approximate values) New: Added on/off of Session Mode on the main screen and timer setting in profile and settings Review with presentation of the work of the feature - has subtitles: Smoking Maniac Youtube chanel Hadron-V1.6-sesion.ecigtheme -
Thanks James, this version is now working ot Windows, thanks for the quick response! However, I have the following problem with the Mac OS version: Since version 30.3, none, including this one, start. No error appears on the screen. Mac OS 13.6 - probably with an older version of Mac, but I can't update it. In the system logs I find the following (attached file) Is there any help for old systems? bug2.txt
Thanks James, this version is now working on Windows, however, I have the following problem with the Mac OS version: Since version 30.3, none, including this one, start. No error appears on the screen. Mac OS 13.6 - probably with an older version of Mac, but I can't update it. In the system logs I find the following (attached file). Can you help? I work primarily on Mac... bug2.txt
Hyperion Remix for DNA Colour Mods
copyman reviewed Serenity E's file in DNA 75 Color, 100 Color, 250 Color
- 4 comments
- replay
- power bank
(and 1 more)
Tagged with:
Version 1.5.0
294 downloads
Information: The theme is based on my previous themes. It works on DNA75C, DNA100C, DNA250C, and in DNA75C/DNA100C does not operate "Power bank" mode. Supports replay. On the idea of vapingbad - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution. Preheat: ***************************************************************** Preheating has several states: 1st is when preheat is on, 2nd is preheat off, 3rd is dropped out of temp protection. 4th is TP-enabled=false, 5th is TS-Material=false. This is how the conditions are set: The TP icon: default shows on image, atty\temp-protect-enabled=false as the condition for showing the off image. atty\temp-sensing-material=false also for showing the off image. Text status: default shows "PH" for preheat atty\preheat-enabled=false shows "---" atty\temp-protect-enabled=false shows "PWR" in yellow atty\temp-sensing-material=false shows "PWR"in yellow atty\temp-sensing-dectect=false shows "???" in orange (tested with an ss coil using a NI profile) Temp Field: atty\temp as default atty\temp-protect-enabled=false shows diag\atty\voltage atty\temp-sensing-material=false shows diag\atty\voltage ***************************************************************** Extras: There are two main screens - extended and easy! In Lock Screen down: Current in charge or root temperature in non charging mode. When using a power bank, an icon is displayed. In Main Screen two resistans: locked ohms and life ohms. In Main Screen right to Power: temperature of board or output voltage in VW mode. In Main Screen right to Temperature: Temperature ot last puff In Main Screen top: The name of the profile below is the material used In Battery Screen: Below is shown what current is the charge, and the displayed power indicates whether the fast charge is on: normal charge - 7.1 watts / fast charge - 13.2 watts (approximate values) Main screen's: Extended 1 Extended 2 Extended 1 Extended 2 Extended 3 *** Only the Centaurus theme has a reworked battery display for now: Easy main screen: Centaurus Hyperion- 4 comments
- replay
- power bank
(and 1 more)
Tagged with:
Works on Mac OS X 10.13.6 High Sierra /DNA100C/DNA XXXX Thanks!
Install ot Mac OS X - Another way to get to the folder if you did not enable the view of hidden system folders:Enter the EScribe menu: Help-> About, press 7 times on the logo Evolve and then enter the menu Option -> Langauge -> Edit like this you open the folder with the translations. Add/replace .po file.
