Everything posted by adski
Here’s my latest. 75c twin 20700 Sanyo 4250mah. Wideboy case from Modmaker uk, fascia, buttons and source 510 from Stealthvape. Batteries soldered into a pack, (no weak battery message here) fascia and lid epoxied shut. Absolutly solid mod, not a rattle in sight. Sorry I forgot to take picture of inside before I glued it.
Come on let's see her in full then.
Let's see your DIY 75c's!! Not trying to be uppity but no mass produced mods allowed and we don't need to know how many ohms or what material your coil is or how many watts you are running at. The original show us your DNA200 was fantastic until people started posting their Lostvape zinc alloy rubbish and such. I have bought a modcrate silo case and have used a Sanyo 4000mAh 20700 battery. Screen holder from the modcrate link to Shapeways. Have also soldered straight to the battery instead of using a sled.(don't own an external charger) FYI the reference 510 copy from stealthvape UK does not fit. The magnets are included in the kit but I have epoxied it shut. I'm in the UK and the silo cost me $15 postage and £13 customs charges.
Hi guys, I want to order a custom 250 and a 60 but the website keeps saying out of stock for all colour combinations. Surely they cant be sold out yet? How are you guys ordering? I'm in the UK if that makes a difference. I even tried using a US vpn. Any ideas? Thanks.
I had the same, low battery message when batteries were only just over half discharged, I ended up soldering an 18650 2s pack to try and same results. I turned my preheat down to the wattage I'm vaping at(around 45w) and now my batteries give me the message around 10-12% on the battery meter. I too have my cut off at 2.9v. I just need to lower the watt hours by 10% to have an accurate meter. Conclusion is that 2s 18650's just aren't man enough for this beast of a chip. If I want more power I just use my lipo dna 200, but just run tanks on the 2s mod.
Good job with the xcube BUT I spy a pack of Marlboro poking out!!
Thanks peeps, they were just abused old batteries. I'm now using 2 x LG mj1's they are rated 10amp constant (not sure on the pulse rating) I'm only using a tank around 40 watts so am not pushing them. I have left the cut off at 3.09v. They are around 25Wh and last for absolutely ages, getting nearly double the vape time I was getting on 1300mAh 3s.
I have been using some old vtc4's in my 2s series mod, I have been getting the low battery screen when my batteries are reading 3.7v each and 3.10ish under load. I assume that both batteries can be discharged a fair bit more than this. Most battery tests I have looked at discharge each cell to 2.5volts. Will setting each cell cutoff to 2.75v give me a safe longer run time? So that the low battery screen comes on when the batteries sag under load below 2.75v? Thanks in advance
Run a wire from pin 1 to the positive that you connect to the board at the sled solder a bridge on the board from pin 2 to pin 3 Run a wire from 2/3 to the opposite end of the sled it does not matter which as they are already connected run a wire from the negative pin to the main battery ground that goes to the board at the sled job done
They are the same. You can solder pin 2 and 3 On the board or run two wires.
The tape that just keeps on giving Kapton
VapingBad you are the man! I must have downloaded an earlier version. Weird because escribe offered me an update.
Nearly finished this one. 2s 18650's just gotta glue the magnets and couple of other little bits. Modmaker case, its a squeeze butt it fits!100mmx50mmx24mm
I reinstalled escribe yesterday when i updated to windows 10 and have since updated escribe.
Windows 10. It does nothing when i click on it.
Thanks but I have already done that but it still says 3cell and wont let me change it.
I have built a 2s mod, how do i change it to 2 cells in Escribe? I cant find it anywhere. Thanks
Can we use 2 18650's in series with no balance charger connected? Just use the USB for software only? Thanks
Love that orange screen. I might have to steal that idea!
My bad, what a douche
I had the chip mounted in a different box with a bigger battery where all wires were 14awg. Switched to the 950 nano battery and didn't bother upgrading the wires as I think john on here said they were good enough as they are silicone coated.
