Wayneo last won the day on March 22
Wayneo had the most liked content!
About Wayneo
  • Birthday August 12
  • Full Name
    Toronto
    DNA 250C, 100C, 80C, 75C, 60C, 250, 200, 75, 60
19,915 profile views
Wayneo's Achievements
Senior Member
Senior Member (3/3)
1.3k
  1. Under the 'safety' tab in escribe, you can adjust that 'fill pod' sensitivity or even turn it off. BUT IT IS WORKING (high watts, low airflow) as you've found out, caused by the wicking not able to keep up.
  2. OK, so you got A bad pod.
  3. No, and no.
  4. I would say the evolv default theme fits that bill.
  5. I don't know, but you can find the chip specs and dimensions on Stealthvape in the UK. I would measure the distance from the bottom actuator to the USB connector. Good luck.
  6. Open a ‘Help Desk’ ticket with your request/suggestion https://bit.ly/4616VB3
  7. In a color theme you can change the fonts used to ones on your PC. Try that.
  8. Post moved to proper area. What I typed still stands. Thank you.
  9. If this is what your mod looks like, remove the panel over the fire button and see if the problem still exists. Is that a color screen on the mod? You can also (with mod plugged in) use escribe - Device Monitor and the bottom line will show what buttons are being pressed. Sounds like a stuck 'down' button, but is it from the board or panel.
  10. Open a ‘Help Desk’ ticket with your suggestion Click Here
  11. Open a ‘Help Desk’ ticket ⬇️ Link in my signature line. ⬇️ Report back with their answers
  12. You can lower or turn off 'fill pod' in escribe - safety tab. Load the latest firmware first.
  13. If that feature works on the 60C you can try the serial command u=0 A to disable charging.
  14. I have no clue about the OXVA quality control. What I can say is I consistently get more than double your 2,000 puffs on the 0.6 pods, and my wife gets more than double what I get on the 0.8 pods. No sweetener DIY ejuice.
  15. Read the post below and try the firmware if you want. https://forum.evolvapor.com/topic/76162-possible-bug-or-board-problem-and-firmware/
