This is based on the DJLsb theme with the following changes/additions:
- Replay Support
Unified main screen:
- In watts mode, displays power.
- In TC mode, displays power and temperature.
- If Replay is enabled, displays Power and Save.
- If Replay is active, displays warmth slider and Cancel.
- Removed color toggle and material selection, replaced with profile selection.
- Selecting Cold Ohms goes to the Atomizer screen. From here you can select material and read/adjust/lock resistance.
- Preheat/Boost screen only shows punch slider if enabled, only shows power/temp if Preheat enabled.
- Single-page info menu.
With version 1.0.0:
