This is based on the DJLsb theme with the following changes/additions:
  • Replay Support
  • Unified main screen:
    • In watts mode, displays power.
    • In TC mode, displays power and temperature.
    • If Replay is enabled, displays Power and Save.
    • If Replay is active, displays warmth slider and Cancel.
  • Removed color toggle and material selection, replaced with profile selection.
  • Selecting Cold Ohms goes to the Atomizer screen. From here you can select material and read/adjust/lock resistance.
  • Preheat/Boost screen only shows punch slider if enabled, only shows power/temp if Preheat enabled.
  • Single-page info menu.
What's New in Version 2.0   See changelog
  • New main screen
    • Added mini-graph, select for Recordings screen.
    • Power/Temp are now side-by-side.
    • Changed Replay controls to a more compact toggle and slider. (Only appears if profile/atomizer can Replay)
  • Cleaned up Info screens, removed Last Puff screen (same info is on Recordings)
  • Added max puff time to Lock settings.
